Decat pipe
gt4tosupra
Removing the 1st cat on top of the other exhaust changes will make the car a little more noisy. The 1st cat on the NA is completely different to the TT one so will not be reusable. It's a pointless change to make if you are planning to change to a TT engine. it'll only make the exhaust even louder, with no real difference to power (air temp will make a far larger difference than a decat on an NA)
Cheers pal, will save the money and leave that one then! What do u mean by air temp tho?
Pretty much, lower air temp = more (free) power :) As intake air temps rises, the engine power decreases. It's one reason aftermarket air intakes that have the induction inside the engine bay reduce power rather than increase it. It is FAR more pronouced on turbo charged cars, but the same applies, in a lesser respect, to NA engines.
