Understanding Big end Bearing sizes
StuartW
I am confused can someone please confirm what size i need please?
I have just double checked the toyota TRD3000 manual on sizing.
It can be found on page 43 of the PDF here http://www.mkivsupra.net/vbb/showthread.php?t=72809
" If size mark on original rod bearing cannot be obtained, (As on mine)
add size marks on crankshaft and connecting rod cap together to
determine size mark of rod bearing. For example, if size mark on
crankshaft is "2" and size mark on connecting rod cap is "1", use rod
bearing with size mark "3"."
My Crank is stamped 101110
My Rods are stamped 212122
So surely i actually need shells sized 313232 ?
The confusion has come about as my Toyota dealer asked be for the number on my con rods when i was ordering the shells. That contradicts what the Reputable manual says and will mean i need 212122 sized bearings :blink:
Can anyone confirm this:search: please, Obviously if i have mis-understood it will blow my engine and race parts up instantly!!
I am confident of the main bearings being correct as they still had readable numbers on the shells and also they DID match up correctly according to adding the numbers on the other end of the crankshaft with the specification table in the toyota manual.
Hope someone can help..
Stuart (Frustrated)
Edited by StuartW (see edit history)
My Block is stamped 101110
Big end Bearing sizes.
Are you using the numbers on the crankshaft and connecting rod cap as you've got the number on the block listed above?
Edited by merckx (see edit history)
  • 2 months later...
I think I,ve gone wrong here. Which numbers on the rod cap do i use?
Theres a number on the bottom wich is part of the casting.
Then theres numbers printed/stamped on either side. I guessing one sides just the assembly guide. And the other side has a number on it.
  • 1 year later...
Ok i have finally come to assembly 18 months later..I have bolt stretch torqued up all the big ends and #1 and 6 are too tight, Surely when using aftermarket rods the only way is to use plastiguage as the OEM rods are individually numbered and different sizes whereas the Carillo rods are all the same...either way its all going back to the machine shop so they can do it...My skills stop at replacing a standard or set +15/30 etc shell after a grind...Its too much to risk.
Nissan and Toyota use these bearing gradings, but we are talking microns here. If you are using a used crank forget them, the sizings will have changed due to wear. I would just buy ACL bearings and do a quick crank journal micrometer check, a quick rod bore micrometer check, and then a Plastigauge bearing clearance check. That should be more than adequate.
