Richie-R Posted April 29, 2009 Share Posted April 29, 2009 When I bought my supra the previous owner sold me a complete set of discs front and rear.Today I got round to fitting the rears.Only I couldn't, the circumferance is too big 32.2cm about 6mm to 7mm bigger all round than what I presume my stock ones are, same pcd etc .I've got a 94 N/A j spec.Does anyone know what these fit so I can sell them or even if I can get them milled down as a couple of mm and they'll clear the calipers.There drilled and grooved and the guy said he got them from the States.Haven't looked at the fronts yet. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted April 29, 2009 Share Posted April 29, 2009 They could be UK spec size, you would need to change the calipers, you may then have wheel fitment issues..... wonder why the old owner did not fit them ........ Quote Link to comment Share on other sites More sharing options...
Steviekid Posted April 30, 2009 Share Posted April 30, 2009 They could be UK spec size, you would need to change the calipers, you may then have Are UK discs not a lot more than 6-7mm bigger than J-specs? Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 30, 2009 Share Posted April 30, 2009 Are UK discs not a lot more than 6-7mm bigger than J-specs? UK/export rears are 324mm and jspecs are 307mm at the back. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 30, 2009 Share Posted April 30, 2009 I have the correct discs if you need them, and I am only just over the Cheshire border. Quote Link to comment Share on other sites More sharing options...
Richie-R Posted April 30, 2009 Author Share Posted April 30, 2009 Thanks Chris planning to come down and see you when I've saved up some cash Quote Link to comment Share on other sites More sharing options...
Richie-R Posted April 30, 2009 Author Share Posted April 30, 2009 Thanks all they are uk spec and so will be in the sales section as soon as I've got time to sort it out.As ever your a helpful lot cheers Quote Link to comment Share on other sites More sharing options...
