paulj1 Posted April 29, 2009 Share Posted April 29, 2009 Has any one used Silkolene SILKTRAN SYN 5 in their 6 speed manual gearbox just I was given some and wondered if this is ok to use Thanks Paul Quote Link to comment Share on other sites More sharing options...
BigDino Posted May 1, 2009 Share Posted May 1, 2009 Hey up flower, not sure but i have some Millers that will you do you just fine. Quote Link to comment Share on other sites More sharing options...
Guest proburt Posted May 2, 2009 Share Posted May 2, 2009 No No no. dont use any thing but the factory fluids in the getrag 6 speed. go to the dealer and get the factory stuff, it has verry specific properties that make it compatable with the syncros in that gearbox. the fluid is very expensive by the way. Quote Link to comment Share on other sites More sharing options...
Kranz Posted May 2, 2009 Share Posted May 2, 2009 Do a search..... a quick look brought up these: http://www.mkivsupra.net/vbb/showthread.php?t=143095 http://www.mkivsupra.net/vbb/showthread.php?t=92481 Quote Link to comment Share on other sites More sharing options...
Guest proburt Posted May 2, 2009 Share Posted May 2, 2009 Do a search..... a quick look brought up these: http://www.mkivsupra.net/vbb/showthread.php?t=143095 http://www.mkivsupra.net/vbb/showthread.php?t=92481 good info I was un aware of the discontinuation of the v160. cant say im surprised though, its getting harder and harder to get factory parts these days. cheers. Quote Link to comment Share on other sites More sharing options...
oilman Posted May 4, 2009 Share Posted May 4, 2009 Getrag six speed boxes run on an ATF as they need a thin oil. Have a look at these http://www.opieoils.co.uk/c-442-atfs.aspx The Amsoil ATF is tried and tested and is a much better quality than the Toyota stuff. The Fuchs 5000 and Redline Racing are also good choices. Cheers Tim Quote Link to comment Share on other sites More sharing options...
paulj1 Posted May 19, 2009 Author Share Posted May 19, 2009 okey doke tahnks for all your help Paul Quote Link to comment Share on other sites More sharing options...
Dave222 Posted May 19, 2009 Share Posted May 19, 2009 Paul Whiffin stocks the V160 if you want the real stuff, quick delivery as well. Dave Quote Link to comment Share on other sites More sharing options...
