Hey, im ganna try and do my bumper myself!
philstowell
Hi all, ive decided toi try and spray and fit my bumper myself, i dont know when im ganna start but i have my eyes on some of the spray kits and all the paints.
just a quick one, has anybody ever used
http://www.expresspaints.co.uk/catalog/products_new.php
and are they any good quality wise?
and im thinking of a clark spray gun, im ganna use a compressed air container to start with incase i just dont have the touch, but all being well ill get a compressor.
i havnt got a clue what im doing so dont expect any pictures too soon, but i will get there im sure.
im probably ganna buy the kit at the end of the month and take it from there in slow time to try and get it right and good.
i will try and get some pics of the disasters that are about to follow as its my 1st time doing anything like this.
cheers for reading this.
phill:banghead::bang:
Did the same with welding a couple of years ago worked ok for me just be patient.Way to go in my book.
i know not to rush in to it, im just ganna take it slow and probably spread it out over a few weeks when i get started, or.........
jump in and get messy ha ha
cheers
phill
Will you be using 2 pack paint?
I painted one of my side skirts with a Devilbiss gun and a secondhand compressor.The finish was very good indeed, all the work is in the preparation and the spraying is easy.:eyebrows:
I dont know yet to be honest, one of the guys here used to do it for a living before joining up so he is going to give me a list to work from.
i cant wait to get started, its just ganna be a night thing so will take me a while to finish, unless i get the knack for it
cheers
phill
If you're doing it for a sense of achievement, and you have suitable premises in which to carry out the work then go for it and good luck. It can be very satisfying. White is one of the easier colours to get good results with. :)
If however, you're only doing it to save a bit of money, I'd get someone else to do it for you. By the time you've purchased all the required materials and hardware, it'll probably cost more than having it done professionally.
For paints and consumables I thoroughly recommend this company. The website isn't particularly slick, but in my opinion the customer service is very good.
http://www.body-shop-warehouse.co.uk/
Im mainly doing it because its one of hose black arts that i have often wondered "how the hell do they do it" and wouldnt mind sussing it out.
hopefully ill get a half decent end product which gives me the satisfaction side.
and cheers for the website details, ill have a look now.
cheers.
phll
Good on you for having a go. I once sprayed some new panels for one of my spitfires, i was quite pleased with the results. As said preparation is the key. I would however never go near my Supra with paint.
Happy days buddy
well, i fugure if i can sus it now, then if i plan on doing a colour change it will be another option, or if i hit any more bloody wildlife ha ha
cheers
phill
I remember the first and last bit of spraying i tried when i was 18.
It actually turned out good, but the main problem is having a nice clean environment to do the actuall spraying. You need it uber free of dust particle etc otherwise they will stick in with the paint on your bodywork.
The actual spraying process was no problem, as long as you keep it a distance away from the item you are spraying and take smooth even stokes with the spray gun, you can't go much wrong.
Good luck chap... It isn't too bad to do..
As said all along, it is in the prep work :) If you don't want to buy a compressor, although I'd really recommend getting one, what about hiring one?
A decent gun is key, Iwata or Devilbiss are the front runners IMHO
Like Gav says, you need the right tools for the job. Compressors are readily available for hire. Machinemart seem to always have loads in the windows when i drive past at the one not a million miles from me.
If you're tyring to save money though, if might not be worth doing it yourself as you will have to get all the right tools. Might actually be cheaper to pay a sprayer, plus at least you get a decent job. You might end up having to pay for it to be re-done anyway!! :D
Nice one.
cheers again buddy
Forgot to add...
Once you get the gun, compressor and associated bits, get down to the local scrappie and pick up some random panels, simply to play with before you do the actual work. Get used to the way the gun feels, how the various controls affect it, how to get the best paint mix, getting the pressure right. All little things that you really want to sort BEFORE doing it :) Also pop down to your local paint shop and buy some random colour in the same paint, they usually have some pre-mixed stuff that a customer didn't want and it is cheaper and great for practice.
Cheers agian, im ganna give it a go with the cannistrs and ten if it goes fairly well, but a compressor.
ill just have to wait and see.
cheers though buddy
cheers though buddy
Out of interest, how big are the cannisters? My little compressor is 50l, and it has to kick in a good few times doing a panel.
