ill goldfish
Branners
Hi folks,
One of my kids goldfish seems unwell. It is just sitting on the bottom of the tank, it moves around every so often but not much. It is normally swimming round the top of the tank quite happilly.
It is a black moor goldfish.
We always did the water change every 2 weeks, but forgot for 4 weeks and now the fish looks extremely ill.
Any recommendations on how to keep it alive?
We have done a 20% water change now and we are hoping it recovers.
mine did that for a while and then after i cleared up the tank and put some chemicals to clear the crap from tap water it was ok.
but then again my other goldfish did that and eventually died, just stayed in one place right at the bottom and would move when i tap the glass.
We'd one that did the same thing, it turned out that the gravel at the bottom of the tank was small enough for it to suck up into its mouth, it had swallowed a few bits and couldn't keep itself 'afloat' due to the extra weight of the stones (stupid fish).
It died, but I was able to replace it before the kids noticed.
Does it look damaged or unusual in anyway? I doubt it is down to lack of oxygen as all the fish would be displaying symptoms then.
It might be worth doing another big waterchange and make sure the water is chlorinated/conditioned before it goes in the tank. Stir up the gravel and suck out the muck, you will be amazed at how much crap collects there.
If there are any signs of bacterial infections or damaged fins, bulging scales etc and you can get to a local fish/pet shop, look for some myxazin and treat the whole aquarium with that.
Also what do you feed them? What type of filteration do you use? The above will probably cost more then a new fish... but I dont think thats the way to look at it.
