_Shane_ Posted April 25, 2009 Share Posted April 25, 2009 hi guys, Went for a spin today in the supra, about 2 hours driving, no screwing the car or anything like that, most of journey was with cruise control on etc Then the engine management light came on and also the Traction control light came on at the exact same time, car kinda chugged for a second and then all was grand again. On way home just there, both lights came on again and car was missing and lost all power, then power came back again. Car was only serviced a month ago. Anyone have any idea on what could be the problem ? I started the car again a few mins ago and i didnt even have it backed out of my driveway and both lights were on and when i gave the car a little rev and the car was like missing again and no power Quote Link to comment Share on other sites More sharing options...
Steve Posted April 25, 2009 Share Posted April 25, 2009 Check for error codes Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 25, 2009 Author Share Posted April 25, 2009 will try this tomor. Anyone have this same problem with the 2 lights coming on at the same time ??? Quote Link to comment Share on other sites More sharing options...
Ian C Posted April 26, 2009 Share Posted April 26, 2009 Both lights coming on is normal "I've got something wrong with me please check the error codes" response from the ECU -Ian Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 from what i can make out the error codes are as follows 14 27 42 here is a video clip of the diagnostic check so if ye wanna just double check i got the right codes i would really appreciate it shane Quote Link to comment Share on other sites More sharing options...
Steve Posted April 26, 2009 Share Posted April 26, 2009 Have a read of this thread http://www.mkivsupra.net/vbb/showthread.php?t=35920 It list the fault codes at the bottom. Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 Ian C said that i should reset the ecu first of all as i could have some old fault codes still stored etc, if i just disconnect the battery will that reset the ecu ? cheers shane Quote Link to comment Share on other sites More sharing options...
supramkivcork Posted April 26, 2009 Share Posted April 26, 2009 That will reset the ecu alright, leave it disconnected for about 10 minutes shane. Quote Link to comment Share on other sites More sharing options...
Steve Posted April 26, 2009 Share Posted April 26, 2009 Yes, disconnect the battery for 5-10 minutes, then reconnect it, go for a drive. If the faults are there it will store the codes which are causing the problems. Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 Will do that mate dont think i can go for drive as the lights were on before i even backed out of my drive and car sounds crap also lol Quote Link to comment Share on other sites More sharing options...
Steve Posted April 26, 2009 Share Posted April 26, 2009 Will do that mate dont think i can go for drive as the lights were on before i even backed out of my drive and car sounds crap also lol Will be easy getting the codes to re-appear then Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 talking to bondango there and he brought up something interesting. I only got the car serviced just over a month ago and while doing that my mate who serviced it was on about the coil pack clips on the first coil pack at the front of the engine saying they were very lose etc had a fiddle around with them there,took them out and put them back in and took car for a quick 5 min spin, no engine management lights or trac light came on Car running as normal now, revving away, boost away as normal. Will still do another diagnosit check when it stops raining outside and will post up findings Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted April 26, 2009 Share Posted April 26, 2009 talking to bondango there and he brought up something interesting. I only got the car serviced just over a month ago and while doing that my mate who serviced it was on about the coil pack clips on the first coil pack at the front of the engine saying they were very lose etc had a fiddle around with them there,took them out and put them back in and took car for a quick 5 min spin, no engine management lights or trac light came on Car running as normal now, revving away, boost away as normal. Will still do another diagnosit check when it stops raining outside and will post up findings Sounds like you have sussed it then mate. Usually seems 9 times out of 10 it is something simple. Bet thats a weight off your mind now Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 it is indeed mate , just hope thats it solved now Ordering new clips for the coil packs tomor and will replace them some evening this week. Will take the car for a longer spin in the min and see how it is. Will do another diagnostics test then afterwards again after i reset the ecu Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 update Went out and reset the ecu, only got 1 error code then - 27 Took car for a spin, all driving well, boost away, no dash lights coming on etc etc then when i change gear or anytime i have the clutch in the revs died and car would cut out. Brought car home and ran diagnostics again - 27 , 42 came up this time round. One of these is the o2 sensor, would ye think this needs replacing or what way should i approach this situation. And finally just before i put car back into driveway i started it again and it pretty much fought to stay alive but after a minute or so the car started to idle as normal again. Any input is much appreciated Quote Link to comment Share on other sites More sharing options...
bondango Posted April 26, 2009 Share Posted April 26, 2009 ECU will take a while to Relearn (usually a good 15mile run), as it will need to relearn its idle strategies etc etc 27 is sub oxygen sensor on the Uk, and shouldnt effect the car running as its used to monitor the cat. Is it actually connected as some people remove it when doing a decat on a UK?? 42 could be faulty speed sensor, but more than likely the buffer circuit, do a search on how to fix. Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted April 26, 2009 Author Share Posted April 26, 2009 (edited) both cats are out of the car also (sorry forgot to mention that) Will run out there and give it a start again and see how it is now brb lol ............. car running grand (didnt drive it) just started it up and perfect idle, rev away and she rests nicely again on idle, no cutting out Edited April 26, 2009 by _Shane_ (see edit history) Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted July 5, 2009 Share Posted July 5, 2009 update Went out and reset the ecu, only got 1 error code then - 27 Took car for a spin, all driving well, boost away, no dash lights coming on etc etc then when i change gear or anytime i have the clutch in the revs died and car would cut out. Brought car home and ran diagnostics again - 27 , 42 came up this time round. One of these is the o2 sensor, would ye think this needs replacing or what way should i approach this situation. And finally just before i put car back into driveway i started it again and it pretty much fought to stay alive but after a minute or so the car started to idle as normal again. Any input is much appreciated Could it be idle control "aparatus"?? Dont know whats its caled in English (Swedish). Quote Link to comment Share on other sites More sharing options...
