Savage switches
mintedm
It is simple enough, however if you aren't comfortable doing it, then I wouldn't advise it...
In a nutshell...
Ground would connect to LED cathode -
12v switched feed would go to common
From the N/O take a wire and connect it to LED cathode + and also to the fog light.
In a nutshell...
works great mate, what one would i swap if i wanted the led opposite way, ie blue light on when fog is off, would it be a case of swaping + and - ?
