2JZ-GE and 2JZ-GTE Differences
leon
Bit of a random question but i was sitting at work reading post about people going NA-T and others droping a TT Lump in.
It got me thinking.
What Parts are actually the same between the two engines?
for example is the block or the bottom end the same? mybe with different internals?
its probably really sad but i thought it was an interesting question.
Using a GT engine to perform like a GTE is always going to be a compromise. The GTE block, when well maintained, is virtually indestructible, even with over 50% more power than the engine was initially designed to deliver, before Toytoa restricted the engine in the MKIV.
the bottom half is baisicly the same i think , minus some oil jets, but the top half is dfferent , or so iv been lead to beleive.
i also know of people that have transplanted the top half from a gte onto a ge bottom half. so if can mix and match bits from each they cant be to different .
Edited by dr_jekyll (see edit history)
Guest sureshot_james
these are the differences I know of from doing the swap na to tt
Block and heads are different
the differences I know are
oil sqirters on the tt and not on the na
tt has the oil holes in the block drilled and tapped for the oil lines to the turbos
oil pan has several different holes tapped and drilled
the bold pattern on the exhaust are different not sure about intake but most likely different
most of the hangers and parts are the same
both blocks have the places for the hole but several of the na's are not drilled/tapped
more to follow but this it what I remember now
Guest proburt
the gte motor comes with forged internal stock, the oil squirters that spray the bottom of the piston, some additional oil gallys all to combat the aditional power and HEAT generated, also the gte power plant uses a distributorless ignition system so those that have gone Na-t have a big distributor stuffed right in front of the turbo inlet. the gte also runs a lower compression ratio.
The gte is for the most part a completely different motor.
Guest proburt
So where are these additional oil galleries? J have never found any. How does an oil gallery combat additional power?? The GTE and GE share the same crank and rods, and neither are forged...
I guess I worded that poorly. With more power, more heat is generated, and the oil squirters that are fed by oil gallies not found in the GE motor help to provide aditional lubrication and dicipated some of the heat.
As far as the forged internals on the GTE I read that some where, since I cant verify the source take it for what youd like.
hope that helps.
Guest proburt
proburt
I'm a newbie
yup
Guess if I had 13,000+ posts it would add some credability.
Thank you Chris :)
As someone who's seen inside these engines more than most I think your input here is quite valuable. Interesting regarding the crank and rods, basically then, NA engine blocks should be as tough as TT ones as they are the same barring the oil squirters?
-Ian
I did weigh a bare TT and a bare N/A block once and I seem tp recall the N/A one being a bit lighter, so maybe they didn't have the same deck thickness, or something? I know RB26 blocks come in 3 types, the normal production, the heavy duty N1 and the very rare GT blocks (about 5 to 6 thousand quid each) for endurance racing.
Well considering the cost of a complete NA engine, it might be a viable starting point for a rebuild to single turbo spec with low comp pistons, a TT cylinder head, and oil squirters getting retrofitted. Hmmm.
Given the current trade price of an N/A, a radical car should be cheapest based on a rot free N/A. You would be binning so much of the vehicle that the base car would be fairly irrelevant. For example, most of the engine internals, the clutch, maybe the gearbox, add a decent spec LSD or complet axle assembly, blah blah. If I were doing a serious project I'd build the engine, clutch and drivetrain first and then buy a really mint car of whatever spec, to nail it all into. These projects get so expensive that the cost of the base car becomes almost trivial.
Edited by Chris Wilson (see edit history)
i love reading the technical posts from chris wilson , id love the knowledge of this guy. keep filling us with your helpful and very accurate knowledge .
The main difference between Chris and most other forum users on the interweb is he's gain his knowledge though experience, not wikipedia.
There is a chap over on the GTR register who thinks WRC cars ran 16bar of fuel pressure :rlol:
Lyndon.
Guest proburt
Not being difficult, but to stop this thread misinforming people in the future, I have to say you are also wrong re the oil squirter gallery. It's the main oil gallery they are fed off, present in both engines.
your right the oil gallys are in both, and both do have forged rods. I did a little research of my own, and found a puplication from toyota motor corporation in 1993 that introduces the MKiv explains the differences its almost 260 pages of technical information. here are some of the differnces that were pointed out in the article.
Direct ignition system
hot wire mass air flow sensor
grouped exhaust ports in head
sub water jacket exhaust side (head)
Oil gallary in the form of a cast aluminum pipe in the piston
oil jets
different valve timng and lift (cams)
water cooled oil cooler
side feed injecters
jet pump fuel system (in tank)
belt tentioner absorber (manual gearbox)
cam sensors
pull type clutch cover
solid clutch disk
fly wheel damper
larger fuid capacity (auto gearbox)
modified valve body (auto gearbox)
4 layer metal head gasket
offset intake ports
wile we are all swinging off chris's nuts
heres some good info check it out.
http://97supraturbo.com/Supra%20Scans/New%20MKiV%20Features.pdf
Edited by proburt (see edit history)
There's one for the quote book.
I hereby propose that in future any reference to doing a job properly, or working from correct and properly researched information is referred to as "swinging off Chris' nuts". :D
