high boost with 2cats on?
Guest Roos
Hello..
Have been reading post for a hour now and dont find any good help to my problem..
But iam from sweden so my english sucks.. :blink:
I have put on the 2cats on my j-spec supra and I get messed up boost pressure. It will not stop to charge to I take the fot of the gas. I have checked the hoses from the wastegate and I checked so the wastegate wasent stuck. Any other way to check if the wastegate works? My Bcc is on 0.80.
Anyone got any idea what I can do next?
Anyone know were to buy a restrictor ring?
To raise the boost your going to have to remove the cats and fit a restrictor ring.
Leaving the cats in is going to raise your exhaust temperatures which is bad. and your not going to be able to raise the boost.
I need the cats on for a while when I get the car surveyed so I can drive it on the roads legal.
The problem is that the boost pressure shouldent go between 0.8 -1,5 or more whit the two cats on, or should it? Shouldent the boost stay on 0.8 if my bcc is on that.
I dont want to raise the boost, I want it o stay on 0.8 :)
The car is imported from japan.
Still have high boost pressure. I wana take and remove the BC and all the hoses and try with out it. But I dont really know how to fit the hoses after I remove it so i get it like its was original.
Anyone have any pictures or something?
