Mike_Mac Posted April 22, 2009 Share Posted April 22, 2009 I've just installed cruise control on my Supra. It had it before, but (I think) when it was imported the crap speedo converter the company installed screwed its operation up, so they cut the stalk connections at the white connector block behind the steering wheel and left the rest of the cruise system in place. All I had to do (once i'd sorted the converter out) was to wire in a stalk and presto! Because the wires had been cut so close to the white connector block I had to remove the pins in the block and put the new wires into the block direct, but obviously this can't be left as is. Does anyone know where I can get new connector pins to re-make the connector block? I can add pictures of the old connectors if necessary. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 22, 2009 Share Posted April 22, 2009 I'm sure that if you sent the pictures to Steve Manley, he would be able to sort you out Mike, other than that try speaking to Jezz or Kieren and see if they have a second hand unit. Quote Link to comment Share on other sites More sharing options...
Mike_Mac Posted April 23, 2009 Author Share Posted April 23, 2009 Cheers Kev - didn't even consider trying to explain what I was after to my local Mr T, but Steve's probably a much better bet! Quote Link to comment Share on other sites More sharing options...
