mathew Posted April 22, 2009 Share Posted April 22, 2009 whenever i seem to go over a rough patch of road, such as a strip of new tarmac which has settled slightly lower than the existing road, the rear end feels as if it jumps to the left. i read that when the bushes are worn it allows more movement in the suspension so im guessing these may be the problem? (although i havnt checked yet) anyone have any different ideas what the problem may be? Link to comment Share on other sites More sharing options...
AlanM Posted April 22, 2009 Share Posted April 22, 2009 Could well be, shocker ok? Link to comment Share on other sites More sharing options...
Dnk Posted April 22, 2009 Share Posted April 22, 2009 Could be down to few things but check the dampers 1st as thats the easiest then your onto bushes, ball joints etc Link to comment Share on other sites More sharing options...
Supra-Brett Posted April 22, 2009 Share Posted April 22, 2009 Sounds like a shocker to me, i had the same problem. If i went over a cats eye on the motorway the whole back end jumped about 4inches:taped: This problems was acompanied by a small knocking noise over bumps. Be prepared to change your upper rear suspension arms as well though as these often go at about the same time as the shocks, and these are pretty pricey if you buy new. These also cause wierd handling problems if worn. Link to comment Share on other sites More sharing options...
3LL Posted April 22, 2009 Share Posted April 22, 2009 should check your bush every now and again for foreign matter... Link to comment Share on other sites More sharing options...
mathew Posted April 22, 2009 Author Share Posted April 22, 2009 Sounds like a shocker to me, i had the same problem. If i went over a cats eye on the motorway the whole back end jumped about 4inches:taped: This problems was acompanied by a small knocking noise over bumps. Be prepared to change your upper rear suspension arms as well though as these often go at about the same time as the shocks, and these are pretty pricey if you buy new. These also cause wierd handling problems if worn. thats excactly what i get. il get it in as soon as poss to have a once over Link to comment Share on other sites More sharing options...
