mawby Posted April 21, 2009 Share Posted April 21, 2009 Just the speaker, not the casing. Free if you pick it up or beer money if you want me to bring it to an event. Link to comment Share on other sites More sharing options...
hadyn Posted April 21, 2009 Share Posted April 21, 2009 What size is it mawby? Im just curious about replacing it for a direct swap aftermarket speaker... Link to comment Share on other sites More sharing options...
mawby Posted April 21, 2009 Author Share Posted April 21, 2009 The core speaker is 185mm x 130mm The speaker including mounting lip is 205mm x 145mm Depth is 70mm Link to comment Share on other sites More sharing options...
hadyn Posted April 21, 2009 Share Posted April 21, 2009 So basically a 6x8" sub or speaker should fit in the factory enclosure? Link to comment Share on other sites More sharing options...
mawby Posted April 21, 2009 Author Share Posted April 21, 2009 It should do yes, but I'm not going to bet money on it. Link to comment Share on other sites More sharing options...
hadyn Posted April 21, 2009 Share Posted April 21, 2009 These look very similar to the speaker you've posted above: http://cgi.ebay.co.uk/KENWOOD-KFC-S6882C-6-X-8-CAR-SPEAKERS-240-WATTS-NEW_W0QQitemZ160328722208QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Speakers_PP?hash=item160328722208&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A2%7C39%3A1%7C240%3A1318 I might try and upgrade the stock sub now. Thanks for the idea Link to comment Share on other sites More sharing options...
mawby Posted April 21, 2009 Author Share Posted April 21, 2009 Remember the stock amp is only designed to power a 25watt speaker, and the factory amp bypass cables you get don't power the factory sub (I think), so you might need to power it from your own amp or run some cables down from the head unit. Link to comment Share on other sites More sharing options...
hadyn Posted April 21, 2009 Share Posted April 21, 2009 The rear sub is working AFAIK with my current setup. The rear window appears to vibrate slightly so somethings working? Link to comment Share on other sites More sharing options...
mawby Posted April 21, 2009 Author Share Posted April 21, 2009 If it works then it works, I'm just pointing out that whatever is powering the current sub is only powering a 25watt RMS speaker, so if you put in a 60watt RMS speaker it may have trouble producing any powefull low frequencies. Probably best to point an ICE techie at this thread and see what they think. I may have it all wrong. Link to comment Share on other sites More sharing options...
wantasupra Posted April 21, 2009 Share Posted April 21, 2009 thats very helpful. mines making a farting noise. thanks b Link to comment Share on other sites More sharing options...
hadyn Posted April 21, 2009 Share Posted April 21, 2009 I think anything would be better than the 17 ish year old bit of paper I've got in there now Link to comment Share on other sites More sharing options...
