Hubcentric spacers- much difference between them?
Dave_SZ-R
Hi everyone,
As you can see from my pic below, I require some spacers, particularly on my rear wheels (yes, I know its best to get wheels that fit properly in the first place, but I got these wheels with the car and cant afford new ones right now!).
Spotted these on Fleabay:
http://cgi.ebay.com/ebaymotors/25MM-WHEEL-ADAPTER-SPACER-MR-2-MR2-CAMRY-SUPRA-SOLARA_W0QQcmdZViewItemQQ_trksidZp3286Q2em63Q2el1177QQhashZitem150329529611QQitemZ150329529611QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Seems to be a good price, is there anything I should look out for in particular? They seem to be the right size, material etc. Bear in mind, this is a temporary solution until I can afford some nice new Weds/ Volks etc!
Also, will I require longer wheel nuts?
Can't see ebay in work but what you are looking for is adapters, as above.
They are centered around the hub and the nuts. You would need at least 25mm looking at the gap in your arches.
Your looking for 114.3x5 and with a 60.1mm bore and spigot location.
