csa Posted April 21, 2009 Share Posted April 21, 2009 After I installed the new engine and the old gearbox, my Exedy twinplate has started to rattle quite alot. This is a bit strange as it didn't really make a sound before. I took the engine out with the gearbox on it, and disassembled the clutch via the inspection opening at the front, to take off the gearbox. When I put it back on, I did the same. I haven't had the clutch off the box, only the flywheel ofcource. Obviously I've assembled it some other way than it was before, but I really can't see it's possible to do on more that one way. any thoughts? Link to comment Share on other sites More sharing options...
csa Posted April 22, 2009 Author Share Posted April 22, 2009 come on guys....surely someone have a say :-) Link to comment Share on other sites More sharing options...
JustGav Posted April 22, 2009 Share Posted April 22, 2009 come on guys....surely someone have a say :-) Turn the radio up? (no help I know ) Link to comment Share on other sites More sharing options...
Rich8v Posted April 22, 2009 Share Posted April 22, 2009 Did you use new flywheel bolts when putting it back together? Link to comment Share on other sites More sharing options...
csa Posted May 5, 2009 Author Share Posted May 5, 2009 no used the same flywheel bolts as they looked brand new. How would that affect the sound? should mention that the flywheel has been balanced with the crank when I did the engine rebuild Link to comment Share on other sites More sharing options...
Scott Posted May 5, 2009 Share Posted May 5, 2009 Is it a new or old flywheel? I have heard of some combo's rattling. Link to comment Share on other sites More sharing options...
csa Posted May 5, 2009 Author Share Posted May 5, 2009 same flywheel on the same clutch Link to comment Share on other sites More sharing options...
AlanM Posted May 5, 2009 Share Posted May 5, 2009 Thought it was mandatory to use new bolts? Link to comment Share on other sites More sharing options...
johnd-mkiv Posted May 5, 2009 Share Posted May 5, 2009 It might quieten down a bit after using it as the plates settle back in, did they go back in the same order? Link to comment Share on other sites More sharing options...
Guest drlee Posted May 8, 2009 Share Posted May 8, 2009 sometimes if plates are put back perhaps in opposite direction.other than original travel,,done it with my hks one!it can be noisier,dont matter.provided everythings tight u shud b cool. d Link to comment Share on other sites More sharing options...
RobSheffield Posted May 8, 2009 Share Posted May 8, 2009 The flywheels bolts are stretch bolts so require replacement at each change of fly Link to comment Share on other sites More sharing options...
tDR Posted May 8, 2009 Share Posted May 8, 2009 If the engine was balanced with flywheel they likely skimmed the flywheel meaning more clearance between it and the clutch plates leading to more rattling. Link to comment Share on other sites More sharing options...
