GavinL Posted September 30, 2002 Share Posted September 30, 2002 Originally posted by Matt Harwood Just to throw a spanner in the works, I've been recommended to get one as I'm already getting 'throttle surge' or 'turbo stall' in my auto if I go from full throttle to just light throttle. could it be that the stock one is faulty? Quote Link to comment Share on other sites More sharing options...
randy Posted September 30, 2002 Share Posted September 30, 2002 Originally posted by Paul E Matt - matter of interest I am looking to get a few bits n bobs from Japan (no offense to anyione selling on-list!0 If you are interested in me ordering you one let me know - I will check on price etc Mail me offlist - cheers Paul:cool: Paul, If you are buying from Japan why don't you look at the SARD R2D2 racing blow off valve? I have this it performs really well and believe me it is loud as hell!:flame Dev Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 30, 2002 Share Posted September 30, 2002 Originally posted by paulrenn Hi Matt, Has your car always exhibited this symptom, or just started? Did you make any changes (ie mods) after which this started? It's fine if I keep the boost below 1.2. Even at 1.35 it's only under certain circumstances like going from full throttle at max revs, the autobox changes up a gear as I reduce throttle to almost nothing. Obviously this is rare, as I don't tend to drive like that, but it can happen on things like busy roundabouts/junctions etc Gavin, the stock one is working OK, I was talking to Leon about the symptom and he explained how BOV's work. I may have mis-interpreted what he said but it seemed clear at the time. Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 30, 2002 Share Posted September 30, 2002 When using the auto box on Manu mode you are supposed to lift off the throttle between changes otherwise you can put almost full torque through the converter during the change. An aftermarket BOV helps to dump all that pressure in the system more quickly than the stock recalculating type. Quote Link to comment Share on other sites More sharing options...
GavinL Posted September 30, 2002 Share Posted September 30, 2002 Originally posted by Matt Harwood It's fine if I keep the boost below 1.2. Even at 1.35 it's only under certain circumstances like going from full throttle at max revs, the autobox changes up a gear as I reduce throttle to almost nothing. Obviously this is rare, as I don't tend to drive like that, but it can happen on things like busy roundabouts/junctions etc Gavin, the stock one is working OK, I was talking to Leon about the symptom and he explained how BOV's work. I may have mis-interpreted what he said but it seemed clear at the time. Probably a manual/autobox thing. My manual car is running 1.4bar no problem. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 30, 2002 Share Posted September 30, 2002 Very possibly as mine only does it when the box shifts up a gear - Maybe due to full throttle gear change??? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 30, 2002 Share Posted September 30, 2002 Matt, never suffered surge on stocks or hybrids but I had an additional BOV. If necessary I'd go new Blitz, although I can get CHEAP HKS kits. Paul the HKS kit comes with mounting kit. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 30, 2002 Share Posted September 30, 2002 Perhaps I do have something else wrong??? - But again, you have a manual car, my 'stalling/blowback' only happens occasionally on auto gearchange at WOT. I'm going to go and see Leon again before 27th, (Want to give you a run for your money Terry! - But only racing on cranking time... See whose car starts first! ), I'll ask him to give it a quick check over. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 30, 2002 Share Posted September 30, 2002 Right it won't be surge on WOT. It's probably the pressure going back through the turbo but a BOV will only help if it happens when you lift off. Ask Leon if he can check your wastegate. Quote Link to comment Share on other sites More sharing options...
