Stripping the wing mirror down
PORNSTARRACING
Need some help guys! inside my mirror there is a chunky gold spring with a cap on top, if checked the mirror over so many times im sure the only way to seperate the main mirror from the base is to remove the cap on the spring, has anyone ever stripped a supra mirror down?
need to seperate the base that bolts to the door from the mirror shell, hope that makes sence, just ragged my brains out thinking about it
thanks
you can do it by cutting the cap off you then need to drillthe post inside the spring,refit by compressing the spring and washer and roll pin or split pin in place of the original cap
ive done it as an experiment for painting purposes and needed to make a tool to compress the spring
its not easy though to get back together
hth
