Clifford problem?????
Dave F
Just heard my alarm going off tried to disarm it and nothing happened also noticed the indicators were not flashing which they normally do. It carried on for about 3-4 minutes then stopped now I cannot start the car and the red led on the dash is not coming on either ( clifford led that is ) Very nearly kicked the car at one point but the calm part of me told me it would not make it better... Any ideas welcome its a concept 300 with intellistart.
Thanks Dave
Sounds like your car battery is flat.
The siren has it's own internal batteries, so that's why it could go off, and explains why you couldn't disarm it, the indicators weren't flashing, and you can't start the car....
Thanks for the replys fellas. Other lights on the dash work when I turn the ignition on as to does the radio is this because they dont need much battery power? I will try and jump start it before calling somebody out I think, but does anybody know a reputable company in north kent who come out and check if it is an alarm problem?
Thanks again Dave
Matt H
Just went out to the car clifford led is working again as to was the key fob when i tried to disarm it. It also started fine so would this still be something to do with the battery or alarm fault. I am not far from sextons if it is not the battery so I may get it checked out there.
