P 17EED Posted April 20, 2009 Share Posted April 20, 2009 Caliper spreader tool thing out of machine mart. Best tenner I ever spent. Before I had that I used a big Screwdriver and prised them back but The proper tool for the job makes life a lot easier. The cube your talking about is for wind back calipers, I dont thing supra calipers wind in, I'm not sure but I think they just slide in so a normal caliper spreader should do the trick. as it has top hap brakes u properly just push the piston back in! Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 20, 2009 Author Share Posted April 20, 2009 deffo off to b n q then Quote Link to comment Share on other sites More sharing options...
Rinus Posted April 20, 2009 Share Posted April 20, 2009 so nu push and turn? I had to do this lately with an audi 80, turn and push is very for jspec and uk brakes its just pushing back the pistons and thats it? I have to do the same job these days with the uk brakes, dba4000 with hawk hp+pads and goodridge brake lines, think it will go even easier with the brake lines removed... Quote Link to comment Share on other sites More sharing options...
madmarf Posted April 20, 2009 Share Posted April 20, 2009 Caliper spreader tool thing out of machine mart. Best tenner I ever spent. Before I had that I used a big Screwdriver and prised them back but The proper tool for the job makes life a lot easier. The cube your talking about is for wind back calipers, I dont thing supra calipers wind in, I'm not sure but I think they just slide in so a normal caliper spreader should do the trick. caliper wind back tools are mainly used for the rear calipers as most moddern cars and some older cars have wind back calipers. you can do it without it but you have to twist and push at the same time, takes forever. they were never on supra front brakes though. jez Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 20, 2009 Author Share Posted April 20, 2009 ahh right cheers Quote Link to comment Share on other sites More sharing options...
pjavon Posted April 20, 2009 Share Posted April 20, 2009 So are the rear calipers wind in or not? Got to do mine this week, I always thought they wound in because of the handbrake but could be wrong. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 20, 2009 Share Posted April 20, 2009 caliper wind back tools are mainly used for the rear calipers as most moddern cars and some older cars have wind back calipers. you can do it without it but you have to twist and push at the same time, takes forever. they were never on supra front brakes though. jez Yeah I had them on the rear calipers of my prelude and I never had the correct tool, had to sit for ages with a screwdriver twisting them in. But as you say you don't need it for the supra, front or rear. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 20, 2009 Author Share Posted April 20, 2009 g clamp £5.95 from bnq sorted Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 20, 2009 Share Posted April 20, 2009 Really should use a wind back tool...... Some calipers require turning as the piston goes back, so it is a useful thing to have for other cars anyway. EDIT: Already been mentioned anyway. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 20, 2009 Author Share Posted April 20, 2009 as said before, supras dont require turning Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 22, 2009 Author Share Posted April 22, 2009 right well i have just had delivered my new brake discs, which would be the easiest to do first, the front or the back??? going to give it a go tonight. cheers Quote Link to comment Share on other sites More sharing options...
Steviekid Posted April 22, 2009 Share Posted April 22, 2009 right well i have just had delivered my new brake discs, which would be the easiest to do first, the front or the back??? The fronts as you don't need to worry about the handbrake Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 22, 2009 Author Share Posted April 22, 2009 why what happens when you do the back, what do i need to do to the hand brake?? Quote Link to comment Share on other sites More sharing options...
Steviekid Posted April 22, 2009 Share Posted April 22, 2009 why what happens when you do the back, what do i need to do to the hand brake?? http://www.mkivsupra.net/vbb/showthread.php?t=105009&highlight=release+handbrake+rotate Quote Link to comment Share on other sites More sharing options...
madmarf Posted April 22, 2009 Share Posted April 22, 2009 Yeah I had them on the rear calipers of my prelude and I never had the correct tool, had to sit for ages with a screwdriver twisting them in. But as you say you don't need it for the supra, front or rear. ahh another ex-prelude owner Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 22, 2009 Author Share Posted April 22, 2009 g clamp worked a treat however ................... i cant get the two bolts undone that hold the caliper bracket on. ggrrrrrr these things are never easy, gonna try and use my mates impact drive wrench tomorrow so calipers and pads back on for now, They are really scored on the inner pads and even after 3 months of use, do you think its worth getting new pads again to put on with the new discs? Quote Link to comment Share on other sites More sharing options...
Steviekid Posted April 22, 2009 Share Posted April 22, 2009 They are really scored on the inner pads and even after 3 months of use, do you think its worth getting new pads again to put on with the new discs? Ideally you'd change the pads too. Or sand them back a bit with emery cloth if they're really new and expensive. Quote Link to comment Share on other sites More sharing options...
madmarf Posted April 22, 2009 Share Posted April 22, 2009 g clamp worked a treat however ................... i cant get the two bolts undone that hold the caliper bracket on. ggrrrrrr these things are never easy, gonna try and use my mates impact drive wrench tomorrow so calipers and pads back on for now, They are really scored on the inner pads and even after 3 months of use, do you think its worth getting new pads again to put on with the new discs? Patience and strength, try to use two spanners ended over each other, "ring over open" to give better length and leverage. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 22, 2009 Share Posted April 22, 2009 ahh another ex-prelude owner not ex, still have it allthough it needs work now its been laid up over winter. Awesome cars and an amazing engine:) Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 23, 2009 Author Share Posted April 23, 2009 Patience and strength, try to use two spanners ended over each other, "ring over open" to give better length and leverage. only had a small ratchet set so going to try my mates impact drive tonight, they are quite rusty so got my plus gas on them, going to try and get a socket bit for my torque wrench as well as that ill give plenty of leverage just in case the impact drive doesnt work the pads i have on there are mintex extremes Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 23, 2009 Share Posted April 23, 2009 only had a small ratchet set so going to try my mates impact drive tonight, they are quite rusty so got my plus gas on them, going to try and get a socket bit for my torque wrench as well as that ill give plenty of leverage just in case the impact drive doesnt work the pads i have on there are mintex extremes Si can you update this thread once you have your mintex pads on and bedded in as I'd like to know what you think of them, I've heard some good things about them but no-one ever mentions them on here. Quote Link to comment Share on other sites More sharing options...
madmarf Posted April 23, 2009 Share Posted April 23, 2009 only had a small ratchet set so going to try my mates impact drive tonight, they are quite rusty so got my plus gas on them, going to try and get a socket bit for my torque wrench as well as that ill give plenty of leverage just in case the impact drive doesnt work the pads i have on there are mintex extremes be easyer buying a bar and 1/2 drive socket. have it off in no time Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted April 23, 2009 Share Posted April 23, 2009 Get a breaker bar on them! Jack the car up, wheel off then turn them so you get a better angle on the bolts. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 23, 2009 Author Share Posted April 23, 2009 yeh just got a scoket for my power bar, ive had my mintex pads on a while now and yeh i really like them, just my discs are like butter at the mo so changing them. will do it tomorrow when i have more light Quote Link to comment Share on other sites More sharing options...
