probrox Posted April 19, 2009 Share Posted April 19, 2009 In November I replaced my drivers side rear hub as I believed the wheel bearing was knackered, due to the noise it was making. It has now started to make the same noise again. Is there anything else which could be causing the noise? It is a grinding noise which occurs once in each rotation of the wheel. I just wondering if there is anything else which could be causing this or if the one i bought was just already on its way out. If it is definately the bearing could there be another fault which is causing this bearing damage? Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted April 19, 2009 Share Posted April 19, 2009 It could be the drum brake shoes rubbing. Does it get louder when rotation faster? Quote Link to comment Share on other sites More sharing options...
Rich8v Posted April 19, 2009 Share Posted April 19, 2009 When my bearing became warn, i was advised to replace the bearing and the wheel hub at the same time and only buy new parts. Quote Link to comment Share on other sites More sharing options...
probrox Posted April 19, 2009 Author Share Posted April 19, 2009 It could be the drum brake shoes rubbing. Does it get louder when rotation faster? It seems to be louder at low speeds, but they may only be because the engine is quieter and I can hear it more. Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted April 19, 2009 Share Posted April 19, 2009 I get something similar. Low speeds with the window open a slight scraping, but at speed nothing. So either something is going to fall off the car or I'll park it on a hill and it won't be there when I get back.. Quote Link to comment Share on other sites More sharing options...
Ian C Posted April 19, 2009 Share Posted April 19, 2009 Have you tried the usual wheel bearing check of trying to move the wheel up/down? Might be a warped rear disk, they go in a way that one spot of the disk is fatter than the rest so once per rotation is scuffs against the brake pads. -Ian Quote Link to comment Share on other sites More sharing options...
alaing Posted April 19, 2009 Share Posted April 19, 2009 Could the hub nut have become loose? Quote Link to comment Share on other sites More sharing options...
little num Posted April 19, 2009 Share Posted April 19, 2009 my passenger side rear was making a noise, couldent find it at all, wen i jacked the car up the noise would go, then 1 day i lost all my brakes and guess what my braided brake line was rubbing on the wheel. Quote Link to comment Share on other sites More sharing options...
probrox Posted April 19, 2009 Author Share Posted April 19, 2009 Could the hub nut have become loose? Before I changed the hub the first time the nut was very loose. I tightened it up and the noise went, but it returned about 2 hours later as it had come loose again. I haven't checked it this time, but if it is loose how can I stop this from happening? What could cause it to come loose? Quote Link to comment Share on other sites More sharing options...
probrox Posted April 20, 2009 Author Share Posted April 20, 2009 Hub nut was loose. Anyone know why this might happen? Quote Link to comment Share on other sites More sharing options...
dandan Posted April 20, 2009 Share Posted April 20, 2009 Hub nut was loose. Anyone know why this might happen? Knackered bearing (and potentially knackered hub and potentially knackered spline on driveshaft). Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 20, 2009 Share Posted April 20, 2009 Renew the outer rear C/V joint (you may have to buy a complete new shaft) and the hub flange. Use a new nut and washer. Torque correctly and pin. Quote Link to comment Share on other sites More sharing options...
probrox Posted April 20, 2009 Author Share Posted April 20, 2009 If I can source a used hub and shaft from a working car is this likely to solve the problem? I really can't afford to buy new parts at the moment as much as i'd like to. Also, if I can get used parts, I know I can use the hub from a tt on an NA but is the shaft the same as well? Quote Link to comment Share on other sites More sharing options...
probrox Posted April 21, 2009 Author Share Posted April 21, 2009 Does anyone know about the driveshaft? I really need to get this sorted as soon as possible. Quote Link to comment Share on other sites More sharing options...
