Tar Spots...
PhatB
I'm giving the car a good clean this weekend, but I have a lot of tar spots over the bonnet and spoiler. I've tried cleaning it with autoglym intensive tar remover but it doesn't seen to do the job.
Anyone have any tips for removing the tar spots?
Cheers
Cheers
You sure it's tar spots, could be industrial contamination as AG tar remover will always shift tar.
If it is IC then the clay bar "should" shift it.
As above, try leaving some of the tar remover over the tar spot before removing, it'll soften the tar slightly and make it easier to remove
Claybar is the other option if you want to incorporate it into your wash routine
Always remember to wax afterwards of course, as both claybars and tar removers will strip your wax layer
