scooby_doo_do Posted September 29, 2002 Share Posted September 29, 2002 Hi, I need to move my front drivers side wing forwards a little... As ever since i've bought the car the gap between the door and the wing has been very close compared to the passanger side... Is this an easy job ? I'm guessing that the wings just bolt on and off ? In this case would it be possible to just loosen the bolts and try to move it slightly... ? How many bolts are there and where are they all ?? Many thanks... Craig. MKIV TT.... Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 29, 2002 Share Posted September 29, 2002 8 bolts from memory. Remember the ones behind the door shut. The most difficult to get to are the 2 underneath. If you have side skirts you will have to remove them to get to these bolts. Good luck. Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 29, 2002 Author Share Posted September 29, 2002 Which will then send me to my next question...How do you remove the sideskirts ? Thanks Terry.. Craig. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 29, 2002 Share Posted September 29, 2002 There are a series of screws at either end of the side skirt. Also they use double side tape along the sill or sealer. Use a stanley knife blade for this. Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 29, 2002 Share Posted September 29, 2002 Originally posted by Terry Saunders .........Also they use double side tape along the sill or sealer. Use a stanley knife blade for this. Very carefully. Mine are stock Toyota skirts and they are fixed along the top edge with tape Quote Link to comment Share on other sites More sharing options...
