supra_si Posted April 17, 2009 Share Posted April 17, 2009 how easy is it to fit brake discs on the front?? ive been quoted 165 for discs and fitting, i know i can get the discs for about 85 quid and fancy doing it myself. does anyone have a guide i can use please... Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 17, 2009 Share Posted April 17, 2009 Its pretty easy, only problems you migth run into is the discs being seized to the hub face which can be a problem if the discs have been on for ages, caliper bolts are a bitch to shift also. Mine almost sheared as they where loctited in. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 17, 2009 Author Share Posted April 17, 2009 nothing like good news lol Quote Link to comment Share on other sites More sharing options...
glanov Posted April 17, 2009 Share Posted April 17, 2009 it should be very easy buddy!! give it a go anyway no point in spending ££££ on laboure if its a fairly handy job Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 17, 2009 Share Posted April 17, 2009 I just swapped over to ls400 calipers and I had set aside a whole day to do it but when I got to the caliper bolts I just couldn't get enough torque on them. In the end I took it to my local garage and I used his 3ft breaker on them but it was touch and go as to whether or not they would shear, you could almost feel the bolt want to snap. That was just mine though, I don't know if all jspecs have loctite on them. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 17, 2009 Author Share Posted April 17, 2009 kk i just want to shell out for something that could be done by myself, i could just source them myself and get a garage to fit them for me, saves me getting ripped off with them sourcing the discs etc Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 17, 2009 Share Posted April 17, 2009 Try it, its dead easy aslong as nothing is seized. I have used pattern discs on all my cars and fitted them myself and it has saved me a lot of money. Worst case scenario is you have to put the wheel back on and drive it to a garage, nothing gained nothing lost, give it a go. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 17, 2009 Author Share Posted April 17, 2009 how are they held in, i have changed the pads before, whats the process to get the discs off?? Quote Link to comment Share on other sites More sharing options...
glanov Posted April 17, 2009 Share Posted April 17, 2009 they will either beat off or there will be a small screw type thing holding them on easy enough!! but someone can conferm this as iv not dun it on the supra yet lol Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 17, 2009 Share Posted April 17, 2009 how are they held in, i have changed the pads before, whats the process to get the discs off?? Mine weren't held in by anything once the wheel came off, but they should have two screws that go in to locate the disc and hold it there whilst you mount everything. They sit flush with the surface of the disc and are usually a star head. In the past i've had them sieze on me but if they do you can just drill them out as it doesn't matter if you damage the old disc. After that all it needs is a few smacks with a rubber hammer and it should come away. Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 17, 2009 Author Share Posted April 17, 2009 right well i will get some ordered tomorrow, cheers for the replies Quote Link to comment Share on other sites More sharing options...
Homer Posted April 17, 2009 Share Posted April 17, 2009 right well i will get some ordered tomorrow, cheers for the replies As others have said, it's an easy job provided you have the tools. Make sure you have a suitably strong torque wrench to get the caliper bolts torqued up correctly. The only gotcha is if the pistons need winding back, be very careful with this and make sure you have the right tools for the job, it is all too easy to damage a piston if they are not pushed back correctly. Are you replacing with OEM discs? Quote Link to comment Share on other sites More sharing options...
Scott Posted April 17, 2009 Share Posted April 17, 2009 Just a quickie on this. How do you guys get the leverage on the caliper bolts without a ramp/pit. I have a 2ft breaker and can't budge them as i can't get any weight behind them. My hand is in the wheelarch and i can't get my weight above it. I want the calipers off to paint them. Going to do the brake lines and fluid too. Cheers Quote Link to comment Share on other sites More sharing options...
Homer Posted April 17, 2009 Share Posted April 17, 2009 Just a quickie on this. How do you guys get the leverage on the caliper bolts without a ramp/pit. It's a bit tight, I normally remove the lower coilover bolt which allows the hub and caliper to be moved down a few inches which gets gives a lot more room to get a socket and breaker bar on. Quote Link to comment Share on other sites More sharing options...
Scott Posted April 17, 2009 Share Posted April 17, 2009 It's a bit tight, I normally remove the lower coilover bolt which allows the hub and caliper to be moved down a few inches which gets gives a lot more room to get a socket and breaker bar on. Ahh good plan, i'll give that a go. Thanks Darryl. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 17, 2009 Share Posted April 17, 2009 Very easy mate take one side off at a time so you can check other side incase you have problem remembering how it goes back and take your time Quote Link to comment Share on other sites More sharing options...
supra_si Posted April 17, 2009 Author Share Posted April 17, 2009 cheers all Quote Link to comment Share on other sites More sharing options...
