Thinking of getting some gauges
DaveSupTT
As my car is ALMOST complete after being off the road for so long (ill have to update my Project thread! :D) I am thinking of getting some gauges inside the car just so I can keep a bit of a check on whats going on!
I already have a boost gauge, and I do have a EGT gauge but this doesn't work.
So, my question is after reading up in the technical glossary, should I replace the broken EGT gauge and get an AFR gauge instead, or should I stick a new EGT gauge in, or would you say that I should have both.
Is there anything else I should consider?
Can anyone recommend any particular ones?
Cheers
It's sometimes cheaper, neater and less labour intensive to install a basic motorsport dash display. I drove behind some fellow in a Skyline the other night, he looked like he was in the window of a cheap brothel from behind, such were the multicoloured lights and things down *both* the screen pillars. `Orrible. You sometimes find early dash's on racecardirect.
You forget that some people like to have lots of pretty coloured lights Chris;)
However i quite agree.
Edited by Tricky-Ricky (see edit history)
I have been having a read of a few threads, and although im possibly considering the Vems duel egt/afr guage mentioned above, are there any other good ones people would recommend?
I found these that other people have spoke about? How do they compare, anyone had experience with any of them?
http://www.aempower.com/ViewCategory.aspx?CategoryID=66
http://www.innovatemotorsports.com/products/db.php
Cheers
Edited by DaveSupTT (see edit history)
