Calliper Bolts Torque?
suprabrown
Correct!
87 Ft. Lbs. 118 N.M
TORQUE SPECIFICATIONS TABLE
Application Ft. Lbs. (N.m)
Brake Hose-To-Caliper Fitting .................... 22 (30)
Brakeline Fittings ............................... 11 (15)
Brake Pedal Push Rod Lock Nut .................... 18 (25)
Caliper Guide Bolts
Front .......................................... 25 (34)
Rear ........................................... 25 (34)
Caliper Torque Plate Bolts
Front ......................................... 87 (118)
Rear .......................................... 77 (104)
Traction Control Pump Bolts ...................... 14 (19)
Wheel Lug Nuts .................................. 76 (103)
INCH Lbs. (N.m)
Bleeder Plug ..................................... 97 (11)
Master Cylinder Mounting Nuts ................... 115 (13)
Master Cylinder Piston Stopper Bolt .............. 89 (10)
Master Cylinder Reservoir Set Bolt .............. 16 (1.8)
Parking Brake Lever Adjustment Lock Nut ......... 48 (5.4)
Power Brake Unit Mounting Nuts .................. 115 (13)
Traction Control Actuator Bolts ................. 115 (13)
I got this from
http://www.max-boost.co.uk/max-boost/resources/SUPRA_MKIV/BRAKE_SYSTEM.PDF
Which came from
Kindly provided by JohnA today :thumbs:
http://www.mkivsupra.net/vbb/showthread.php?t=36467
With an open ended spanner of a known length, a spring balance and some maths. :innocent:
LOL. I've done it this way before, the torque wrench wouldn't go low enough and it was something fairly critical on a car I was working on years ago. I didn't want to guess. ;)
I was thinking of using a torque wrench????
I was only thinking of the banjo connection at the caliper end!!!
Thanks for the info guys, I'm collecting the calipers tomorrow, so should be going back on this weekend.... I'll post some pics when thay are on.
cheers
markb
I'm glad people have already started using the manuals.
The more hands-on expertise we acquire here, the less bollox we'll have to tolerate from 'authorised dealers' and similar ripoff artists. ;)
I've been stung more than once in the past :complain: , and vowed 'NEVER AGAIN'
Ive had to buy a little mini torque wrench that does really low settings , primerilly to do cam bolts up , bloody £175 :cry:
Dude :cool:
