Mike B Posted April 15, 2009 Share Posted April 15, 2009 OEM Flywheel.. on the way out possibly. Running a ferra-metallic paddle clutch.. I have an intermittant rattle when the car is hot. Thought it was a release bearing but when we had a preliminary look inside we found that there is 3" of play on the flywheel. Is the OEM toyota a Dual mass flywheel? Is it possible to put an aftermarket solid one on - and how does that effect the performance - rattle and bite? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 15, 2009 Share Posted April 15, 2009 OEM flywheel has over 3" of play when new, in fact i think its more like 4" Quote Link to comment Share on other sites More sharing options...
Mike B Posted April 15, 2009 Author Share Posted April 15, 2009 really? ok, back to the drawing board... that's good.. it's probably the release bearing as I suspected. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 15, 2009 Share Posted April 15, 2009 Quote from manual, put machmarks on the primary flywheel, measure the circumferential length between the machmarks, std 105mm (4.134 in) if lager than std replace flywheel. Quote Link to comment Share on other sites More sharing options...
Rinus Posted April 15, 2009 Share Posted April 15, 2009 solid flywheel will rattle very much.. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted April 15, 2009 Share Posted April 15, 2009 OEM is dual mass Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 15, 2009 Share Posted April 15, 2009 solid flywheel will rattle very much.. OEM is dual mass I think he means most clutch set ups that use solid flywheels rattle, IE multi plate/paddle etc. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted April 15, 2009 Share Posted April 15, 2009 I think he means most clutch set ups that use solid flywheels rattle, IE multi plate/paddle etc. I know. OP asked if it was dual mass, nobody answered so i did Quote Link to comment Share on other sites More sharing options...
