toyo rob Posted April 7, 2005 Share Posted April 7, 2005 does anone know where i might procure a piece of rubber, or reinforced silicon, pipe for the oil return from the turbo. just had the turbo's done as well as the stem seals and when the mechanic put the pipes back on a couple were so hard the split. he changed and subbed what he could but recommends i get the correct pipes. so any help would be much appreciated. cheers Rob S Quote Link to comment Share on other sites More sharing options...
Ian C Posted April 7, 2005 Share Posted April 7, 2005 The stock oil return pipes are metal... I fear I may be misunderstand what bit you mean, can you elaborate? -Ian Quote Link to comment Share on other sites More sharing options...
toyo rob Posted April 7, 2005 Author Share Posted April 7, 2005 all i know is that the mech said it was an oil return pipe from the turbo the the sump. from what i can see, as i have a pipe in front of me (should have explaind it in the beginning i guess) it's a 4 1/2 to 5 inch in length about 1 inch diameter and a 30-45 degree bend in it. if thats any help it will be a miracle, cheers Rob S Quote Link to comment Share on other sites More sharing options...
LeeT Posted April 7, 2005 Share Posted April 7, 2005 all i know is that the mech said it was an oil return pipe from the turbo the the sump. from what i can see, as i have a pipe in front of me (should have explaind it in the beginning i guess) it's a 4 1/2 to 5 inch in length about 1 inch diameter and a 30-45 degree bend in it. if thats any help it will be a miracle, cheers Rob S ive just removed all my hoses. if you can get a pic of the pipe i can probably let you have it. Quote Link to comment Share on other sites More sharing options...
toyo rob Posted April 8, 2005 Author Share Posted April 8, 2005 ok got some pics. new pipe is yellow, i only need to change it cause it was straight and now has a slight kink. Quote Link to comment Share on other sites More sharing options...
