how to setup wireless remote for canon eos 300d rebel
geoff meade
How does it connect Geoff ? Is there a hotshoe adaptor or does it connect somehow to the wired connection?
I have a wired remote shutter release on my 300D and it just works, you don't need to change any settings. I'd presume that the camera would just work automatically if it was compatible :search:
Mike
I've just done a search, and realise it must use an IR sensor on the camera. one of the articles I found had this:
As this remote works via infra red you will need to be in front of the camera to fire the shutter.
could this explain anything?
Mike
http://www.velocityreviews.com/forums/t250068-canon-remote-control-rc5-versus-rc1.html
http://www.tomshardware.com/forum/36684-5-canon-rebel-300d-remote
Remember, though, these are infra-red and therefore line-of-sight.
The sensor is on the front of the grip just below the shutter release so you
basically have to be in front of the camera for it to work.
Maybe a problem with wildlife stuff?
I made a manual release with a cord that I could make an extension for. Check
this page for info if needed - http://www.chantalcurrid.com/remoteControl.htm
first of thank you for the help .
in the instructions it says:
,press the button and rotate main command dial until (delayed remote) or (quick response remote) is displayed in the control panel.
well for the life of me i cant see anything that says any of that in the control panel in my 300d
thanx
geoff
got it of eBay the description is below:
JIANISI Infrared Wireless Remote Control
for Canon EOS 450D/400D/350D/300D/30V/30/33/50/300
Ideal replacement for RC-5
do you think i bought the wrong one ??
another question if you can help
is there any way of getting the driver for the canon eos300d for windows 64bit xp ??
