brake upgrade
Guest tommynufc
Guest tommynufc
hi new supra owner with j spec brakes fitted.has anyone fitted aftermarket brakes lets say brembo brakes if so could you tell me where i could get the mounting brackets from so i could lets say get the brembo set up from a range rover and mount the calipers to the supra with the right bracket? has it been done?it would be cheaper than buying the set up from brembo?
You can get a supra sepcific Brembo setup from them. It's not an area you want to skimp on!
There are also more cost effective options such as the stock larger brake supra setup, AP Racing, etc...
The most cost effective is normally to fit decent pads and discs to your current setup, they are more than enough for street use, unless you drive at very high speed, or like your track days.
I think it was SupraDibbs who had a set fitted to his car from an Evo?
There's a noticeable difference between Uk spec brakes and J spec ones (std) in operation, so I wouldn't discount the UK ones until you have tried them.
What sort of Supra did you end up going for in the end Tommy? Have you got any pics? :)
i think evo brakes would have been alot easier just because of the size. i guess mine are more for show.i would prob never notice the differnce between mine and ukspec
I think yours would be more suited for stopping trains and tankers.:D
