Zofix Posted April 14, 2009 Share Posted April 14, 2009 I'm going to order a transmission oil cooler for my supra. I'm looking at the B&M 70298 SuperCooler Oil Transmission Cooler w/ FAN which include 1/2 NPT fittings & thermal switch. Link to photo of cooler: http://static.summitracing.com/global/images/prod/large/bmm-70298.jpg But I have NO IDEA which size hoses or how long, or which adapters and fittings I need to complete this install. I want to mount it in the side vent where the stock IC normally is. And I want to run the oil cooler after the stock cooler in the rad (which many on this forum recommented. Can you guys please help me which hoses and fittings I need for a complete install? Because I have absolutely no idea. Pics of brackets would be great too. Thanks! Quote Link to comment Share on other sites More sharing options...
Zofix Posted April 14, 2009 Author Share Posted April 14, 2009 Nobody:(? Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted April 15, 2009 Share Posted April 15, 2009 You'll need 10mm (3/8") ID oil and heat resistant (up to 125deg C should be ok) rubber hose and hose clips to match. Mount the cooler first, then measure the length required for each run. Looks like you'll need 1/2" NPT to 10mm (3/8") hose tails & thread sealant. Go for 90 degree elbows as these will make installation easier. Take the cooler to your local hydraulic parts supplier and explain what you need. He should be able to sort you out. Can't help with mounts, I made mine out of 50mm x 3mm ally strip. There are some usefull M8 holes in the side of the chassis leg for locating the mounts (presumably these are where the active spoiler mounts??). Use rubber bobbins to isolate the cooler from excessive vibrations. Wherever the hose runs close to bodywork protect it to stop it chaffing. 15mm lagging held with cable ties works well for this (domestic plumbing stuff). If you have to cut holes anywhere to run the hose, then use rubber grommets as the edge of the hole WILL cut through the hose over time. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Zofix Posted April 17, 2009 Author Share Posted April 17, 2009 I don't think they make 1/2" NPT to 3/8" hose.. I can't find it anywhere on the net. they only make 1/2" NPT to 5/8" hose.. Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted April 18, 2009 Share Posted April 18, 2009 I don't think they make 1/2" NPT to 3/8" hose.. I can't find it anywhere on the net. they only make 1/2" NPT to 5/8" hose.. That's 1/2" to 3/8" hose tails mate, not hose. The 1/2" thread screws into the female port in the cooler whilst the 3/8" hose fits onto the other end. Quote Link to comment Share on other sites More sharing options...
Zofix Posted May 23, 2009 Author Share Posted May 23, 2009 Done! I just installed my new B&M Transmission oil cooler. Can anybody tell me if it is ok to mount it this way with the hose lines fitted in the bottom of the cooler? Somebody told me that it may be a problem due to cooler being empty when the car is shut down? But when I look at photos of the stock EU-spec trans cooler it is mounted the same way as I did. Do anybody know? Quote Link to comment Share on other sites More sharing options...
Robert Posted May 23, 2009 Share Posted May 23, 2009 I had my cooler with the hoses at the top. Worked very well for me and i had a B&M 11" x 11" plus a spal 7.5" fan. Quote Link to comment Share on other sites More sharing options...
