bromy Posted September 28, 2002 Share Posted September 28, 2002 Could someone please tell me what brake pads/part number i need for my 97 n/a, the diameter of the disc is 295mm and 16mm thick i could hear some squealing yesterday from the nearside rear so this afternoon i took it to pieces to find that the pads only have about 3mm left on them and that the wear detector on the pad was making the noise being in contact with the disc, so just to get me around locally i got the angle grinder out and ground it back, i also checked the piston in the caliper (undid the reservoir cap) pumped it right forward but had to get a 'g' clamp on it to get the piston to retract fully, after a road test the disc/wheel is now quite hot, my second question is what is the best way to go about recon this caliper, can i just pop the piston out clean it all up with emery in a lathe and put it back together regards nick Quote Link to comment Share on other sites More sharing options...
GavinL Posted September 28, 2002 Share Posted September 28, 2002 and hello to you too Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 28, 2002 Share Posted September 28, 2002 A short introduction to other member always goes down well before launching in with your problems. Welcome to the BBS. It sounds like you need a referb kit for your callipers, not expensive about £28 form Toyota if I remember correctly. You also need some fluid, probably no need to go as fare as a lathe. The slider may also be a bit stiff. If you get stuck, I have a working set of TT brakes for sale. Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted September 28, 2002 Share Posted September 28, 2002 thats got the same type of relocating spacer i have on my supra.its the only way my 17" split rims fit on my car. they look like jap spec to me think they need some work to bring them back to life i tried to clean mine up a bit with drill and wire brush,also had a go on the wishbone`s they come up a treat not that you can see them Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 28, 2002 Share Posted September 28, 2002 Only just found the image attached. That disc looks shagged. 3mm on a pad is fine1mm is the limit before the squealer hits the disc. My TT rear were running 1.5 mm of pad until a couple of days ago with and squealing. Could be the disc is so warn that the metal tag was hitting the part of the disc not warn away. Have you checked disk thickness limit should be stamped on the disc. In side the calliper the rubber seal has probably gone hard making the piston stick on braking. They look just the same as Jap TT rears to me. Quote Link to comment Share on other sites More sharing options...
bromy Posted September 29, 2002 Author Share Posted September 29, 2002 i must apologise to the group for my rude/none introduction of myself my name is nick broomhead and i live in macclesfield, cheshire, i have owned my 97 gunmetal n/a for around 6 months now the car is totally standard apart from 18" rh rims, image below, thanks for the information i never thought about disc being so worn the 'squealer' was rubbing the unworn part, possibly time for new discs. nick Quote Link to comment Share on other sites More sharing options...
Dragonball Posted September 29, 2002 Share Posted September 29, 2002 Hi Nick Dont worry m8 - you have enough grief living that far North! Good news is that you have Chris not far from you? The geography's crap - OK! Shropshire's not too far is it? Hope you enjoy your car! Cheers Paul Quote Link to comment Share on other sites More sharing options...
