Guest BobbyC Posted April 13, 2009 Share Posted April 13, 2009 Hey peoples I need some help badly as i'm scratching my head and creating a bald patch! Ive just replaced most of the interior bulbs with blue ones - ash tray, ignition barrel light, ciggie light etc. I've also replaced the speedo, rev counter and fuel and heater bulbs with uprated LEDs. All was working fine, put the dash back in and tested it and then...nothing. No lights on the main dials and also the ash tray light now don't work either!? I've done the basic of checking all the connections, checked all the fuses and taken it all out and put it back in and still nothing. Has this ever happend to anybody? I'm stumped and the car's still in bits! If anybody knows what/where or how to fix it let me know! Ta very much! Quote Link to comment Share on other sites More sharing options...
Jamesy W Posted April 13, 2009 Share Posted April 13, 2009 Possibly the fuse in the footwell? Quote Link to comment Share on other sites More sharing options...
Guest BobbyC Posted April 13, 2009 Share Posted April 13, 2009 checked em both mate! Thats what is confusing me, cant see any blown fuses or anything. Do supras ever trip the lights for any reason if ya put LEDs in? Quote Link to comment Share on other sites More sharing options...
absz Posted April 13, 2009 Share Posted April 13, 2009 Is the dim switch on the right hand console connected ? as the feed for the dash dials goes threw that switch. Quote Link to comment Share on other sites More sharing options...
heckler Posted April 13, 2009 Share Posted April 13, 2009 checked em both mate! Thats what is confusing me, cant see any blown fuses or anything. Do supras ever trip the lights for any reason if ya put LEDs in? no they don't - could well be a short somewhere, possibly its damaged the dimmer switch, if its not connected, the dash lights wont work - So, its its damaged/broken it will have the same symptoms. Quote Link to comment Share on other sites More sharing options...
Guest BobbyC Posted April 13, 2009 Share Posted April 13, 2009 no they don't - could well be a short somewhere, possibly its damaged the dimmer switch, if its not connected, the dash lights wont work - So, its its damaged/broken it will have the same symptoms. Hey dude, was just gona pm you for advice! So if the dimmer's damaged, none of them will work? The dimmer switch seems to be ok, aside from not actually dimming the lights (but the new ones still worked before all went wrong?!) I'll check that side of things in the morning again and hope thats the case, if it still aint working i'll drop ya a msg from work. Also, how much for the heater control, cigar ring, odo and clock in blue? Quote Link to comment Share on other sites More sharing options...
heckler Posted April 13, 2009 Share Posted April 13, 2009 Hey dude, was just gona pm you for advice! So if the dimmer's damaged, none of them will work? The dimmer switch seems to be ok, aside from not actually dimming the lights (but the new ones still worked before all went wrong?!) I'll check that side of things in the morning again and hope thats the case, if it still aint working i'll drop ya a msg from work. Also, how much for the heater control, cigar ring, odo and clock in blue? No worries on the questions/advice £60 for heater control, cigar ring, odo and clock Quote Link to comment Share on other sites More sharing options...
Jamesy W Posted April 13, 2009 Share Posted April 13, 2009 I've had these symptoms before, after checking all fuses etc,, I eventually got an auto spark to check it over. Turned out to be a blown dimmer switch, instead of sourcing a new one though I just had it bridged out. Quote Link to comment Share on other sites More sharing options...
Guest BobbyC Posted April 13, 2009 Share Posted April 13, 2009 Cheers fella, I'll have a play with the dimmer and hopefully that will cure it, spent two days fixin an swappin bits out and its buggin me now lol. Sweet, i'll be treatin myself the them end of month for my bday then. Didint fancy takin the heater apart! Quote Link to comment Share on other sites More sharing options...
Guest BobbyC Posted April 13, 2009 Share Posted April 13, 2009 I've had these symptoms before, after checking all fuses etc,, I eventually got an auto spark to check it over. Turned out to be a blown dimmer switch, instead of sourcing a new one though I just had it bridged out. I may just do that, the dimmer switch never worked since ive had it! an im too cheap to replace something that pointless lol! Quote Link to comment Share on other sites More sharing options...
