sealant for rear crank seal??
d_d
Hi guys
Ive just taken my gearbox out to replace the rear crank seal. I could see it was weeping.
Just wondering if i should be putting any sealant on the seal?? as it looks like there was some old sealant on it before
And is it a pig to put back in??
Also the bell housing on the engine there looks to be a join on the bottom which also looks very oily.
Looks like a big job to fix tho???
i did consider that method chris, but the housing seemed to be on there proper, and was worried about resealing after.
Is it my imagination or is there a join in the housing to. Im not sure if there is a smidge of oil coming out of that to altho looks like a major job.
no join on the housing, i removed the complete housing on mine and bought a tube of red sealer from my local car spares place, as toyota sealer is like £50 for a small tube and does exactly the same as the normal stuff you buy, the plate on mine was very tight but i flat head screw driver soon got it off, im in the process of changing the front seal as it started leaking quite bad, after removal its very easy to see why it was leaking, it had gone hard and the spring that normally holds it tight was off when i removed it.
