Cavalier SRi engine noise
AlanM
it will be quicker to remove the sump and only cost you a gasket if thats not the problem. removing the head will mean spending more ie headgasket hydraulic lifters etc. and the problem might still be bottom end which i think it is.
sounds like bottom end to me too...take the injector plugs/connector off one at a time to see if the noise reduces at any time...better to do it with these instead of the plug leads as it has a wasted spark system and your liable to burn out the coil pack when doing that.
Obviously do it running....
Sounds like the metal egr pipe is split a little too...
Sumps on these are rubber and fit around a baffle plate, sump bolts have to be replaced using thread lock and Torqued to 6nm...to stop pan gasket weeping oil through the bolt threads.
Vauxhall tech ? you could be very handy;)
Now that head is off problem is easy to see - a great amount of one of the valve guides managed to get in to the cylinder to get mashed on to the top of the piston. Might have been lots of relatively small particles because the valve appears to be undamaged - not that it is going to be re-used. Photos of piston and head later
Picked up another head today and it is stripped and in to Precision Engineering (a local company for checking. The piston is knacked but the bore looks fine, it is not scored or anything. Think by the sound of him (my eldest) he might take the opportunity to do a total rebuild
