Supra specific Brembo BBK torque settings?
RobSheffield
On the 6 pot/4 pot kits, what torque settings are used for the 2 bolts into the hub and the 2 into the brackets and lastly the 'banjo' bolt through the braided lines.
Hi Rob the torque settings are:
Bracket to hub 118Nm (87ft.lbs)
Caliper to bracket 115Nm (80ft.lbs)
Banjo Bolt 20Nm (15ft.lbs)
Bleed Screws 14Nm (10ft.lbs)
Hope this helps mate :thumbs:
