Supra rattles underneath when stationary
SupraTRD83
Recently took my supe to Kwik Fit (only place open last sunday) as I found that when I pulled up at lights there was a rattle from under the car, doesn't do it all the time but its really annoying. Then yesterday it decided to do the same noise as I was at around 3000rpm and was just about to change gear it made the noise? any ideas? Kwik Fit said it might just be a bit of play in the exhaust but didnt do it before :( my cars an auto
Sounds like it could be the heatsheild around the cats.
Get the car either on a ramp or on stands, start it up, get underneath it and have a listen. If the noise stops when you hold your hand on the heatsheilds, theres your problem.
Be careful if the car has had a chance to warm up. things will be pretty toasty under there :D
EDIT - you boys are too fast for me :D
