Pig Posted May 17, 2012 Author Share Posted May 17, 2012 Sorry to drag this old thread up but I feel it is really important for someone who maybe searching to see the result of this. The car has been pulling...REALLY BADLY to the left for a LONG time. (as you can see, since 2009). I have thrown thousands and thousands at it to sort it and never solved the problem. I am embarrased to say (see the first few posts where everyone mentions tyres) that I fitted a new set of front tyres yesterday and the car drives perfectly straight, just like a new car. I am fuming with myself for not checking the basics first, so if you are reading this with an issues check your tyres and not just the pressures. Thanks everyone for your help, shame I didnt listen much back in the day Quote Link to comment Share on other sites More sharing options...
David P Posted May 17, 2012 Share Posted May 17, 2012 Name and shame the dodgy tyres. Quote Link to comment Share on other sites More sharing options...
absz Posted May 17, 2012 Share Posted May 17, 2012 I see you did't take my advise then !!! LOL Quote Link to comment Share on other sites More sharing options...
Caesard Posted May 17, 2012 Share Posted May 17, 2012 Dummy Quote Link to comment Share on other sites More sharing options...
Pig Posted May 17, 2012 Author Share Posted May 17, 2012 R888's. It is my fault, I obviously messed them up and didn't changed them. I'm used to spinning out and thinking its all ok...clearly it's not. Thanks for the sympathy Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 17, 2012 Share Posted May 17, 2012 Was the left hand one more worn or something then? At least it's fixed Quote Link to comment Share on other sites More sharing options...
Pig Posted May 17, 2012 Author Share Posted May 17, 2012 Was the left hand one more worn or something then? At least it's fixed I'm not sure to be honest Ian as there is no way I expected this to sort the problem so didn't check. I did see a huge flat spot on the os one when I working on the car at the weekend but haven't checked the other. This has caused a major vibration for ages now. ( bear in mind I don't use the car though ) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 19, 2012 Share Posted May 19, 2012 Has it had new top and bottom front wishbones? has it ever been smacked into a kerb? Quote Link to comment Share on other sites More sharing options...
Pig Posted May 20, 2012 Author Share Posted May 20, 2012 Has it had new top and bottom front wishbones? has it ever been smacked into a kerb? Yes and yes Quote Link to comment Share on other sites More sharing options...
RobUK Posted May 20, 2012 Share Posted May 20, 2012 Yes and yes Has it been driven like it was stolen all weekend Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 20, 2012 Share Posted May 20, 2012 (edited) The front upright on the side(s) that hit the kerb are probably bent. Even quite a light knock can bend them. Change it. Having the old one digitised or jigged to see if it is bent will cost more than a new upright. Edited May 20, 2012 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Iky Posted May 20, 2012 Share Posted May 20, 2012 The front upright on the side9s) that hit the kerb are probably bent. Even quite a light knock can bend them. Change it. Having the old one digitised or jigged to see if it is bent will cost more than a new upright. Excuse the simple question Chris, but what do you mean by 'upright' ? The shock? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 20, 2012 Share Posted May 20, 2012 Hub carrier, the main casting that holds the hub bearings that the bottom wishbone ball joint taper goes into. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 20, 2012 Share Posted May 20, 2012 A "PROPER" dynamic geo check would show this up, proper geo checks are few and far between though. Quote Link to comment Share on other sites More sharing options...
