supra matt Posted March 30, 2015 Share Posted March 30, 2015 Cracking work mate looks spot on, Quote Link to comment Share on other sites More sharing options...
The Raven Posted March 31, 2015 Author Share Posted March 31, 2015 Another good morning, and i have fitted the facelifted headlights, and cleaned them up Started like this Ended up like this Now the car looks like Quote Link to comment Share on other sites More sharing options...
supra matt Posted March 31, 2015 Share Posted March 31, 2015 She's a beauty mate Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 31, 2015 Share Posted March 31, 2015 Massive improvement. Quote Link to comment Share on other sites More sharing options...
supra joe Posted March 31, 2015 Share Posted March 31, 2015 That dash out pic scares the shit out of me ! Quote Link to comment Share on other sites More sharing options...
The Raven Posted March 31, 2015 Author Share Posted March 31, 2015 That dash out pic scares the $#@! out of me ! It used to scare the poop outa me to. But it looks alot worse than it is. I used to dread the heater matrix now not so much, i would say 2 hours to get it out? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 31, 2015 Share Posted March 31, 2015 Mmm those new headlights suit the car way better, what did you do with your old ones? Quote Link to comment Share on other sites More sharing options...
The Raven Posted March 31, 2015 Author Share Posted March 31, 2015 I still got them, one of them is letting in moisture so will need to be resealed. I will probably sell them interested? £60 to you mate Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 31, 2015 Share Posted March 31, 2015 I still got them, one of them is letting in moisture so will need to be resealed. Cover them in slightly diluted washing up liquid and then put a hair dryer on full blast at the main beam inlet, basically presurise the headlight, and hopefully bubbles will appear where it needs sealing Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 31, 2015 Share Posted March 31, 2015 Looking absolutely stunning now mate Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 6, 2015 Author Share Posted April 6, 2015 Well looks like I missed a plug on the loom. Nothing major just the climate control would not work. It was cold or hot. Turns out that next the then 3 vents in the dash panel is a tiny 2 prong plug that controls it. Took the dash panels off and found it. Now it's all working fine again Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 1, 2015 Author Share Posted May 1, 2015 Looking at the start of the thread imageshack removed most of my pictures, so i have put some of them back. Those stickers............................. Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 23, 2015 Author Share Posted May 23, 2015 Had colin over to today to fix the oil leak i was having, turned out to be the turbo oil feed was lose, tightened up and all is good. Now we took it for a test drive, with the F&F music playing 2nd turbo about to kick in..................the roof comes off...........i forgot to bolt it down. Lucky i caught it and we wedged in the car till i could pull over. Who needs a punch mod...just dont use bolts. Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 25, 2015 Author Share Posted May 25, 2015 Well in true just my luck fashion. Took the car out today and i seem to have lost the 2nd turbo. Guess would be a pipe from taking it apart to get to the turbo feed. So next weekend i will be back to trying to fix it again. Still could have been worse i could have lost the roof and had no 2nd turbo Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 25, 2015 Share Posted May 25, 2015 Lol you are having the worst luck with this car, should be an easy fix though hopefully just a perished pipe or even better just loose. Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 25, 2015 Author Share Posted May 25, 2015 Lol you are having the worst luck with this car, should be an easy fix though hopefully just a perished pipe or even better just loose. My guess is something loose as it was boosting fine when it had the weep on the oil feed, ive looked around but cant see anything. Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 2, 2015 Author Share Posted June 2, 2015 (edited) OK the boost issue i am now thinking is the coil packs, as its missing on full WHOOT So i have brought some new ones and will be fitting them as soon as they are here. Edited June 2, 2015 by The Raven (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 6, 2015 Author Share Posted July 6, 2015 (edited) Been a while since i updated this had a a major loss in the family. Anyway. The boost issue? a vac hose.......6 hours i looked for it. Colin came over and found it in around 40 SECONDS! So easy fix. Well the other news is the farmer over the road must have sprayed something on the fields that drifted over. The paint went very milky pink with bright spots!?!?!?!?! So i figured i could just clean it off....Seems not i ended up have to cut it all back again. After spending 3 weeks of wet sanding it last year it was a bit gutting. But i cracked on anyway with a swirl remover and the D/A lucky it took what ever it was off. 3 days later the end result was pleasing to say the least. Edited August 18, 2015 by The Raven (see edit history) Quote Link to comment Share on other sites More sharing options...
supra matt Posted July 6, 2015 Share Posted July 6, 2015 Morning mate good to see you back hope you and the family are bearing up ok after your sad loss, on a brighter note looks like nath is having fun in the car Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 6, 2015 Author Share Posted July 6, 2015 Cheers mate. Thats my friends lad, I dont know if you saw this thread http://www.mkivsupra.net/vbb/showthread.php?324166-Its-lightning-McQueen!!!!!!!!!!!! His older son now wants me to take him to the prom in it, and his little son thinks its the Disney car. Quote Link to comment Share on other sites More sharing options...
supra matt Posted July 6, 2015 Share Posted July 6, 2015 (edited) Are sorry mate no did not see that thread, pleaseed your mates kids appreciate the classic lines of the supra and and my ex is obsessed with lightening macqeen and when you're car was dropped off that's the first thing she said lol, Edited July 6, 2015 by supra matt (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 6, 2015 Author Share Posted July 6, 2015 (edited) Im going to get the eye sun screen from ebay, both nath and conner will get a kick out of it, Yeah i remember you saying that now! Edited July 6, 2015 by The Raven (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 4, 2015 Author Share Posted August 4, 2015 Dam car. A few weeks of using it and it broke again, this time its losing P/S fuild at a huge rate. I had a quick look and it seems to be quite close to the reservoir. I will have to take the battery and stand out to see. I think it might be as simple as a split hose. I dont think its anything to bad. If its a hose then it just reinforces my plan to change as many of the rubber hoses as possible. Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted August 4, 2015 Share Posted August 4, 2015 Oh no man fingers crossed for you. Get it sorted and en joy Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 6, 2015 Author Share Posted August 6, 2015 O wow ok, yeah the top ps rubber pipe is fubar. Easy fix i guess. More than ever i want to changed as many rubber hoses as i can now Quote Link to comment Share on other sites More sharing options...
