which boost gauge is lying
legendswraith
As the new maps just gone into the car and i have the boost cut removed thru the emanage i can now boost to 1.2bar properly without any problems. However i have noticed that the profec reads lower than the defi's, there is approximately 0.1 - 0.2 bar difference between them with the boost controller gauge showing the lower.
Considering they should both be getting the same pressure feeding them which is going to be most accurate, or will it be a case of trying to test them against a known pressure to determine it.
Any opinions?
