Removing Water feeds
Steve
After having to remove my fuel rail to fix a fuel leak (the fitting is now welded so wont leak again :D), i was going to remove the water feeds that go to the IAC valve and the throttle body whilst i have the intake off.
Is there any reason why i shouldnt do this?
Can i just blank the feed pipes off or should they be joined together to keep a circuit?
Thanks
I removed the 2 feeds on the throttle body, but left the IACV one in place.
One length of rubber hose from the block to the IACV and job sorted :)
Thats what i was thinking, so basically it keeps it as stock but without going through the throttle body (and IACV
in my case).
If you use the car in very cold, humid weather the removal of the water feed to the TB *COULD* cause it to ice up and *COULD* cause the throttle to stick open. Would / V / Could is for you to decide.
How cold are we talking Chris?
mine are off, the IAC is just looped through till i could be a**ed to do a proper job, i have had no connection to the throttle body for around 2 years, 1 year of that was daily driving to work in the winter (car garaged), i now have a "spare" car that i use for work so the supra doesn't come out in the cold anymore, i would be slightly concerned if the car was outside all night in the dead of winter and maybe left for a few days you could get icing problems, the IAC would not be to much drama as eventually it would defrost as the engine got warm but a sticking throttle is pretty scary, at the end of the day mines a pampered pet that lives in a heated garage, if yours is outside and you expect it to run reliably all winter i would leave them on
