Water Pump Fun
AlexJames
so...
Finally sorted out the over heating problem (Rad Cap) ... when the gasket gell on the water pump gave way and started spitting everywhere...
On closer inspection, the water pump I have doesnt fit correctly. I knew it wasnt excact in the first place but thought I could over come this... I was wrong...
This is the pump that is on, you can see on the top left of the pump, it raises higher.
This is the pump that I need...
Are these the difference between uk pumps and import pumps?
Yes mate, looks very similar to the one posted by bender though, the part number on the box is 16100-49846.
Thanks James...dont suppose I could get a pic? just cause the other one thats on her now looks similar but still doesn't fit ;)
