ShamelessTT Posted April 8, 2009 Author Share Posted April 8, 2009 If i turn the Boost controller to off, i should get stock boost right? im very nervous about giving it the beans at the moment due to the over boost, im perplexed Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 8, 2009 Share Posted April 8, 2009 If its plumbed in right have you checked all the settings on the controller, gain levels ect? Did you disturb any of the other vac pipes while fitiing? Bit odd to have 0.9 bar and then 1.4 bar without doing anything different. I know its a pest but what about trying the car without the boost controller connected and see how the car behaves? By that I mean put the plumbing back to normal. Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 8, 2009 Share Posted April 8, 2009 Yes, if the controller is set to off you should have standard boost. Have you tried it? Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted April 8, 2009 Author Share Posted April 8, 2009 Well the gain level are set to 15 currently i believe and the boost map is all set to default, which is Speed and all the blue lines in the OFF section. When it was stock it was getting 0.84 bar boost, cats removed + 52mm RR + no boost controller, 0.94 and no boost issues at all. Boost controller plumbed in boost all over the shop...... Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 8, 2009 Share Posted April 8, 2009 Is boost all over the shop even when the controller is set to off? A gain of 15 is maybe a little on the high side for the supra. I have mine set to 5. I dont think this is your problem but a gain set too high will cause it to overboost slightly Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted April 8, 2009 Author Share Posted April 8, 2009 Well i havent tried with it set to "OFF" , ill certainly drop the gain a little. Something to do with boost lag or something, im not quite sure why its got set at all. Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 8, 2009 Share Posted April 8, 2009 Mmmm, If it was me I would give it a run with the controller set 'off' as this should give you stock boost levels. If it does and the car behaves when turned off then it should prove your plumbing is correct and that it must be something to do with th settings on the controller. Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted April 8, 2009 Author Share Posted April 8, 2009 Yeh ill give it a go with switched to "OFF" see what happens, thanks for the input. Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted April 8, 2009 Author Share Posted April 8, 2009 SUCESS!!! im chuffed. 1.2 bar, or any bar i like between 0.9 - 1.2(obviously). Thanks to everyone who helped me with this thread. The car now boosts great constant and agressive. Gain : 5 Manual Mode :66 = 1.2bar Manual Mode : 55 = 1.0bar OFF = 0.92bar Anyway it was settings ,after doing what you said and testing it with boost controller OFF i got the stock boost so piping was OK. Then i took it off Auto mode, and moved the value up from on manual mode. The boost became constant and really steady. I think AUTO mode is sh*t, it seems to try and learn the boost, which is no good if ur car over boosts!. Anyway im absolutely chuffed, so i couldnt resist this (see attached) . Quote Link to comment Share on other sites More sharing options...
