3LL Posted April 7, 2009 Share Posted April 7, 2009 well, christmas time my crank pully went, today it seems im havin probs with another pully not turning. the fan is also rubbing against the fan shroud now, which is stopping it turning. its very strange as the fan doesnt seem loose and i cant understand why all of a sudden its rubbing on the plastic shroud! anyways, can anyone identify what pully this is in the atached pic. So far I have had to fix a split power steering pipe and re fill the rad and coolant tank after it kettled last night on me outside my house! not havin much luck! Quote Link to comment Share on other sites More sharing options...
heckler Posted April 7, 2009 Share Posted April 7, 2009 runs the aircon pump Quote Link to comment Share on other sites More sharing options...
3LL Posted April 7, 2009 Author Share Posted April 7, 2009 would that cause a strange squeeling noise also dude? [not from the belt but the pump] the reason i ask is at first i thought it was the power steering pump as the hose had split.. i have replaced this, and re filled the reservoir and its still making the noise. any ideas on the fan not turning / rubbing on the plastic surround? im guessin thats more than likely my reason for overheating last night tbh.. Quote Link to comment Share on other sites More sharing options...
heckler Posted April 7, 2009 Share Posted April 7, 2009 would that cause a strange squeeling noise also dude? [not from the belt but the pump] the reason i ask is at first i thought it was the power steering pump as the hose had split.. i have replaced this, and re filled the reservoir and its still making the noise. any ideas on the fan not turning / rubbing on the plastic surround? im guessin thats more than likely my reason for overheating last night tbh.. did you bleed the PAS system properly? Quote Link to comment Share on other sites More sharing options...
3LL Posted April 7, 2009 Author Share Posted April 7, 2009 filled up and turned the steering about twenty times each way Quote Link to comment Share on other sites More sharing options...
heckler Posted April 7, 2009 Share Posted April 7, 2009 filled up and turned the steering about twenty times each way ahh, has to be done with no weight on the wheels Quote Link to comment Share on other sites More sharing options...
3LL Posted April 7, 2009 Author Share Posted April 7, 2009 ahh, has to be done with no weight on the wheels aaah, gotcha, urm, only got one jack.. ill have to se if theres anywhere at front end i can lift from. the rest of the strange happenings on the car are pissing me off puzzling me too! lol I may have to take the bugger into the garage at this rate me thinks! Quote Link to comment Share on other sites More sharing options...
madmarf Posted April 7, 2009 Share Posted April 7, 2009 well, christmas time my crank pully went, today it seems im havin probs with another pully not turning. the fan is also rubbing against the fan shroud now, which is stopping it turning. its very strange as the fan doesnt seem loose and i cant understand why all of a sudden its rubbing on the plastic shroud! anyways, can anyone identify what pully this is in the atached pic. So far I have had to fix a split power steering pipe and re fill the rad and coolant tank after it kettled last night on me outside my house! not havin much luck! you sure its not turning? on air con pumps they spin freewheel untill you press the air con button inside and the clutch on the pump kicks in and then the whole pulley spins up. will look like its not turning untill this happens . Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted April 7, 2009 Share Posted April 7, 2009 ..... Quote Link to comment Share on other sites More sharing options...
