Do i run oil squirters on a built engine using Wiseco sport compact pistons?
StuartW
Just building up the shortblock, The Wiseco sport compact pistons (Or any Aftermarket 2JZ piston) does not have the channel in the piston crown for oil cooling like the OEM pistons.
SO is it worth leaving the under piston crown oil squirters in?
I guess they will help cool the underside of the piston crown even on the wiseco's?
The OEM pistons have a cut out in the piston skirt to accomodate the squirters but it seems the Wiseco skirt is at its longest, shorter than the OEM piston, So they should clear the squirters no problem? Can anyone confirm this please and discuss the comments i have made.
Regards
Stuart
Edited by StuartW
Made an oopsie!/!? (see edit history)
