bigsup69 Posted April 7, 2009 Share Posted April 7, 2009 Tried searching and tried a few simple things but still no luck in getting it started. The engine turns over fine but seems like its either not sparking or the immobiliser is stopping it (as had a different car before with a clifford on and that immobilised itself), also if you press the pedal a few times while turning it over you can hear it splutter from the what sounds to be the exhaust. Its not been run properly for at least 2 months and the fuel has been in the tank for around 5- 6 months when it was run every weekend (only had quarter of a tank in though) but i have recharged the battery, checked the tightness of terminals, checked for any lose or split hoses etc, checked fuses in the engine and going out in a minute to check the rest, tried different things with the alarm after reading the toad ai606 booklet and seems to be working as it should. Tomorrow was going to check the spark plugs and that the fuel pumps working and getting fuel to the engine, anything else that might be worth checking? and yes i'm checking these first and then if still not something simply (like it ever is) I will be taking it to a specialist. Also its a single turbo auto. Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted April 7, 2009 Share Posted April 7, 2009 (edited) bigsup 69 is running garrett 4088 turbo, not sure what ecu / injectors??? both standard i think??? all info helps Edited April 8, 2009 by wilkorangerover (see edit history) Quote Link to comment Share on other sites More sharing options...
AJI Posted April 7, 2009 Share Posted April 7, 2009 battery might be knackered, even though you had a charger on it. Do you have a voltmeter?? Check the voltage across the terminals to see if it is holding 12v. Most modern batteries do not like being fully discharged, and charging them might build up a temporary voltage but it won't last long and probably won't get upto the 12v of standard power. Quote Link to comment Share on other sites More sharing options...
tomgeer Posted April 7, 2009 Share Posted April 7, 2009 Clean the spark plugs off and try it first of all, sounds very similar to what happened to mine, once I wire brushed the plugs it started straight away and it's been as good as gold since. Quote Link to comment Share on other sites More sharing options...
bigsup69 Posted April 7, 2009 Author Share Posted April 7, 2009 Thanks guys will check later but never let the battery go completely flat and it has been disconnected while sat in the garage Quote Link to comment Share on other sites More sharing options...
