toyo rob Posted April 6, 2009 Share Posted April 6, 2009 i realsie this is a shot in the dark at best but is there a difinitive list of problems that cause the main fault light, the big orangey !, to appear on the speedo. picked the car up from a respray today and the thing came up and stayed up. even though nothing was done to the engine. could it be something silly like air leak on the untake or something, that may have been knocked when they put the new front bumper on??? unfortunately info is thin and i appreciate any ideas/list of things it could be for me to start going through them 1 by 1. by the way, the only problem the whole way home was the sbc not working, the car was overboosting to the max i set of 1.35, nothing else seemed out of place. Rob Quote Link to comment Share on other sites More sharing options...
tomgeer Posted April 6, 2009 Share Posted April 6, 2009 If you haven't already I would check the boot is shut properly first and then the doors, easiest and so obvious you may just have forgotten to do it. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2009 Share Posted April 6, 2009 Have you had a new bumper fitted and active spoiler removed? The ECU will detect if the front spoiler isn't working and will show the warning light. Easiest fix is to press the button to off. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted April 7, 2009 Share Posted April 7, 2009 Run a check on fault codes, probably the easiest thing to do. Quote Link to comment Share on other sites More sharing options...
snake Posted April 7, 2009 Share Posted April 7, 2009 brake light bulb blown? Quote Link to comment Share on other sites More sharing options...
toyo rob Posted April 8, 2009 Author Share Posted April 8, 2009 ok here i go; checked the doors and boot - both ok and when open the little little comes on as expected nic - yes i have had a new front bumper- and the little green light was flashing for the active spoiler so i pressed the button in for off and then unplugged the cable -= was that too far... will test today. how do i check the fault codes - never done it on the soop. the little bulb light is always on because previous owner took 1 set of brake lights out for use as the fog light. and i havent taken the time yet to figure out the cables to stop that from happening... thanks for all the input - will keep look at your suggestions and give the answers later (i hope).. Rob Quote Link to comment Share on other sites More sharing options...
caseys Posted April 8, 2009 Share Posted April 8, 2009 nic - yes i have had a new front bumper- and the little green light was flashing for the active spoiler so i pressed the button in for off and then unplugged the cable -= was that too far... will test today. how do i check the fault codes - never done it on the soop. I'd go with Nic's thesis, but leave the button plugged in. A while ago a garage did work on my car and knocked the button to let the active spoiler go back on. When I took it on the bypass on the way home I had the shock of my life when I saw the warning light come on under WOT. Luckily it was just the non-existant spoiler trying to come down. For fault codes check here: http://www.mkivsupra.net/vbb/showthread.php?t=35920 Edit: In fact you can see the forum highlights fault codes so just click on the hypertext Hope this helps Si Quote Link to comment Share on other sites More sharing options...
toyo rob Posted April 9, 2009 Author Share Posted April 9, 2009 cheers, plugged the switch back in last night, it was dark though so i hope it was the right one, and switched the button off - but no luck. the light is still flashing no matter waht i do... Rob Quote Link to comment Share on other sites More sharing options...
toyo rob Posted June 18, 2009 Author Share Posted June 18, 2009 this is really getting annoying now, i have taken off the battery (for other reasons) so therfore should have reset the ecu but still everytime i switch on the ignition the main fault light come on and the active spoiler lights flashes constantly, wheter i press the 'down' then turn it off, turn it off or even try to leave it on. does anyone have any ideas how i can get this to stop, i dont think i could drive the car with the main warning light on constantly...... if i take out the spoiler ecu would that kill it??? could i place a small resistor between two point where the motor used to be to fool the ecu into thinking its still there??? i am so frustrated i am tempted to see if i can get an old motor just to plug in.... help please Rob Quote Link to comment Share on other sites More sharing options...
mathew Posted June 22, 2009 Share Posted June 22, 2009 my warning light comes on under hard acceleration and heavy breaking. all fluid levels are fine so dont know what is causing it. Quote Link to comment Share on other sites More sharing options...
JODY T Posted June 22, 2009 Share Posted June 22, 2009 unplug the spoiler ecu too, hopefully thatll do it Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted June 22, 2009 Share Posted June 22, 2009 is your spoiler permantely down or does it retract like normal standard Quote Link to comment Share on other sites More sharing options...
toyo rob Posted June 23, 2009 Author Share Posted June 23, 2009 its been totally replaced with a c-west front. thing is i seem to have 'lost' the second turbo and since the light is on i'm not sure if the main ecu goes into some sort of emergency mode when the Main Fault light is on for extended periods. if not i have then got to go through the system again to see if i can fault find why the car went into respray running perfectly and came out running fine for 30 odd miles then lost turbo no 2. i'll take the spoiler ecu out and then go from there i suppose. thanks for the help Rob Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 24, 2009 Share Posted June 24, 2009 my warning light comes on under hard acceleration and heavy breaking. all fluid levels are fine so dont know what is causing it. It's your brake fluid Quote Link to comment Share on other sites More sharing options...
