Gaz Walker Posted September 26, 2002 Share Posted September 26, 2002 Sorry if anyone thought this was going to be another porno thread The motor is getting serviced next weekend, Im using the following bits: Valvoline Synpower 5w40 Gen. Toyota Oil Filter Gen. Toyota Fuel Filter Gen. Toyota Air Filter Gen. Toyota Timing belt NGK BKR7E Sparkies Type IV Autobox fluid ATF Dextron 2 P/S fluid Full coolant change Is this the best stuff for each application? Anything else need doing or should be looked at? Car has done just over 69k miles - didn't have a FSH when I bought it as it was maintained by a mechanic so I am not fully sure what needs doing. I want a clean sheet so that I can start the mods... Thanks Gaz. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted September 26, 2002 Share Posted September 26, 2002 Maybe an auxilary belt as well, depending on how it looks. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 27, 2002 Share Posted September 27, 2002 Diff oil. Supposed to be changed every 36000 apparently. Leon Drained the 50,000 mile sludge from mine yesterday. I was quite shocked to see the difference in oil colour and more importantly, all the metal shite stuck to the magnetic drain plug:eek: Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 27, 2002 Author Share Posted September 27, 2002 Cheers matt, forgot about that 'un... Any specific oil for that? BTW I know brake fluid is missing, I am doing that in one hit (pads,discs, re-paint calipers, braided hoses) later on... Gaz. Quote Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted September 27, 2002 Share Posted September 27, 2002 Hi Gaz, Cant believe you forgot the screenwash m8 and while your at it how about 2 new wiper blades. :p :p Regards Andrew(dunk)Shaw Black uk mkiv tt Quote Link to comment Share on other sites More sharing options...
