Supra Steve 856 Posted April 4, 2009 Share Posted April 4, 2009 Hi everyone, I need help! i have a TT Jap import Auto, and i have a core plug with a hole in it its located under the turbos and is the closest one to the bulkhead, how dificult is this to change and can anyone tell me what to expect? i have experience on working on cars (stripping engines, and putting back together etc) and so im going to attempt to fix this myself... though if anyone can give me some tips, or hints on any problems im likely to encounter that would be great! also how hard are the core plugs to fit? and where can i get them from?? i hope someone can help me with this! thanks in advance, Steve. Link to comment Share on other sites More sharing options...
Scooter Posted April 4, 2009 Share Posted April 4, 2009 member "Bens747" did one or more on his NA (but he's not on here alot).......i would get one from a toyota dealer.........i think you just have to get a drift to tap it in flush......maybe with some sealant....access will be your biggest problem i think. Not sure of the height of the core plugs in relation to all the turbo stuff but hopefully they are lower than most of it so you only have to remove the cats? Link to comment Share on other sites More sharing options...
madmarf Posted April 4, 2009 Share Posted April 4, 2009 (edited) not sure what to remove on the location of it on a supra. but in general, changing a core plug can be tricky. easyest way i find is to use a small but strong and sharp headed screwdriver and keep tapping it in but in towards the centre aswell (to stop damaging the head/block. once you have been patient lol and got through you can carefully prise it out. be patient they can take a while, and be very very carefull not to damage the engine. always best to get a garage to do it if your not confident. once its out clean up the area with a little emery cloth and make sure there is nothing left in the chamber. i normally leave the coolant all in so it helps put pressure behind the plug. i use a socket on a small extention, the exact size of the core plug inside and tap it in will a little white grease. carefull again, dont deform the plug, if you deform it even slightly then youll have to start again. once nearly in all the way use a bigger socket and flush it in. Edited April 4, 2009 by madmarf (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2009 Share Posted April 5, 2009 Unless you can get a straight direct blow to the new one, with a suitable drift and hammer you'll struggle. I'd say the best thing is pull the engine and change them all whilst it's out and do the oil seals, too. Link to comment Share on other sites More sharing options...
Supra Steve 856 Posted April 5, 2009 Author Share Posted April 5, 2009 Hi guys, thanks for your responses, trouble is im going to have to do the work with the engine in the car, i dont have the money or tools to take the engine out unfortunately well im going to start work on it today, i think im going to try get to them from the top, so i gotta take the turbos off! dont have a clue how to, so if anybody can give me some advice there that would also be cool lol thanks guys! Link to comment Share on other sites More sharing options...
merckx Posted April 5, 2009 Share Posted April 5, 2009 Toyota Service Repair Manuals Link to comment Share on other sites More sharing options...
Supra Steve 856 Posted April 5, 2009 Author Share Posted April 5, 2009 WOW!!! hey that is exactly what i needed!! there is complete instructions on how to remove them, and properly!! Thankyou merckx, thats really helped! all i need now is to find a place where i can get the core plugs from! Link to comment Share on other sites More sharing options...
merckx Posted April 5, 2009 Share Posted April 5, 2009 hey that is exactly what i needed!! there is complete instructions on how to remove them, and properly!! I'm pleased you found the right section in the manual as I couldn't, it's a great manual with a heck of a lot of pages. Link to comment Share on other sites More sharing options...
Supra Steve 856 Posted April 6, 2009 Author Share Posted April 6, 2009 Yeh i found it really usefull, its got pretty much everything on there, so i downloaded the whole lot for an future work too, very helpfull, thanks... does anyone know where i can get the core plugs from now? thanks guys! Link to comment Share on other sites More sharing options...
merckx Posted April 6, 2009 Share Posted April 6, 2009 does anyone know where i can get the core plugs from now? Toyota, I'm not sure which one you'll need. From the thread below it looks like there are 2 different sizes, 11 one size and 2 another. http://www.mkivsupra.net/vbb/showthread.php?t=166126&highlight=core+plug+part Link to comment Share on other sites More sharing options...
bens747 Posted April 6, 2009 Share Posted April 6, 2009 (edited) member "Bens747" did one or more on his NA (but he's not on here alot).......i would get one from a toyota dealer.........i think you just have to get a drift to tap it in flush......maybe with some sealant....access will be your biggest problem i think. Not sure of the height of the core plugs in relation to all the turbo stuff but hopefully they are lower than most of it so you only have to remove the cats? Yeps I did two of them and as said it's access to the core plug itself. If you can get clear access then they are very easy to do. They are not recessed as peeps might think so using a blunt tool like a short rod like a drill bit but not. Tap one side of the core plug slowly and it should twist in it's housing. Once removed use a gasket sealant and spread around the new core plug. Using an appropiate sized socket that is the same size as the rim of the new core plug. Very slowly and lightly tap the core plug into it's housing until flush with the enging housing. Do not use a tool and tap in the base of the core plug as you might distort it or put a hole in it. Good Luck ..... Edited April 6, 2009 by bens747 (see edit history) Link to comment Share on other sites More sharing options...
