ABS warning light HELP PLEASE!
scubaman
Hi guys if anyone could help with this it would be greatly appreciated
I changed all of my shocks for Bilsteins yesterday! Everything went well with that and the car now handles 1000 times better!!
This morning I got the car out and drove about 20 - 25 mins away to go to the cinema. When I came out the ABS orange light and the master "!" light in the dash were both on. I checked the brake fluid level which was fine and drove home.
I have now done the self diagnosis test and all I get is "no faults stored" message.
But every time I start the car, all the lights come on as they should, but the ABS and the master "!" don't go out.
Can anyone tell me what this might be?? I presume it has something to do with the shock work yesterday???
you may have knocked a sensor or dropped some crud down by the hub off the old shock or out the arch. have you got any brake cleaner? if so spray it down the sensor pick up and visauly check theres nothing there. im not sure if the new shocks would have affected it, never heard it before. more likely just a dirty sensor. try unplugging them aswell and checking the connectors.
