scooby_doo_do Posted September 26, 2002 Share Posted September 26, 2002 Just a quick one... I'm not sure if i'm being stupid here but if you get new turbo's on your car do you have to wear them in like when you get a new engine or do you just run them normally. ? As in can you go out and push the max boost straight away or will they last longer if you gradually put the boost up over a few weeks or so ? Ta.. Craig. TT 6 Quote Link to comment Share on other sites More sharing options...
GavinL Posted September 26, 2002 Share Posted September 26, 2002 Originally posted by scooby_doo_do Just a quick one... I'm not sure if i'm being stupid here but if you get new turbo's on your car do you have to wear them in like when you get a new engine or do you just run them normally. ? As in can you go out and push the max boost straight away or will they last longer if you gradually put the boost up over a few weeks or so ? Ta.. Craig. TT 6 Under advice I ran mine at low boost for 1000 miles. Quote Link to comment Share on other sites More sharing options...
